Project tug boat Q's about ESC
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Boats General Discussion >> Project tug boat Q's about ESC
Page: [1]
Login
Project tug boat Q's about ESC - 6/30/2007 2:39:59 AM
zooman
Status: offline
Hello
I'm planning on building a tug boat using a electric trolling motor used for fishing. It's 12 or 24 volts. I boat is going to be 3 to 4 wide and 5 to 6 feet long.
I need info on speed controler that would handle that kind of power. The motor is 4HP .
Any info or ideas you have I want to hear them.
       Post #: 1
RE: Project tug boat Q's about ESC - 6/30/2007 3:01:53 AM
Umi_Ryuzuki
Status: offline
MCD probably has a big one you can use.
http://www.modelcontrol.com/
They are typically used in large robots.
< Message edited by Umi_Ryuzuki -- 6/30/2007 3:02:07 AM >
_____________________________
Nyow!
=^o^=
(in reply to zooman)
       Post #: 2
RE: Project tug boat Q's about ESC - 6/30/2007 3:20:41 AM
ryan_t888
Status: offline
Wow, that's about 124 amps on 24v and 250 amps on 12v, if it is geared/propped for 4hp. Do you photos of this beast?
Ryan
A theory may be so rich in descriptive possibilities that it can be made to fit any data. - P.J.L.
       Post #: 3
RE: Project tug boat Q's about ESC - 6/30/2007 3:33:36 AM
zooman
Status: offline
It's an older minn kota motor 4hp is the rating...
(in reply to ryan_t888)
       Post #: 4
RE: Project tug boat Q's about ESC - 6/30/2007 3:35:35 AM
ryan_t888
Status: offline
Ya I have a Minn Kota 30 pound thrust trolling motor. No clue how much power that is. I don't think its any where near 4 hp as a deep cycle will last a a few hours at speed 5.(maxed)
Ryan
       Post #: 5
RE: Project tug boat Q's about ESC - 6/30/2007 3:41:12 AM
Maggster
Status: offline
Maybe I am missing something obvious, but why not use the speed control from the trolling motor?
It may take me a while, but when I'm done it sure looks like a rush job.
       Post #: 6
RE: Project tug boat Q's about ESC - 6/30/2007 3:41:57 AM
zooman
Status: offline
The motor has 4 Hp on the side of it. I would use the speed controler but it's 5 forward and 4 revrerse.
Not enough control.
< Message edited by zooman -- 6/30/2007 3:42:43 AM >
       Post #: 7
RE: Project tug boat Q's about ESC - 6/30/2007 3:44:50 AM
zooman
Status: offline
I don't need reverse as the motor will spin 360'. I'm going to mount it in the middle of the boat.
       Post #: 8
RE: Project tug boat Q's about ESC - 6/30/2007 3:45:45 AM
Maggster
Status: offline
I was right, I was missing something obvious
       Post #: 9
RE: Project tug boat Q's about ESC - 7/2/2007 4:30:53 AM
green-boat
Status: offline
Have you checked out Vantec http://www.vantec.com/
If olive oil comes from olives, where does baby oil come from.
(in reply to Maggster)
       Post #: 10
RE: Project tug boat Q's about ESC - 7/2/2007 9:42:07 AM
LtDoc
Status: offline
Zooman,
From what's been posted I would say you have two choices, spend lots of money, or sort of cobble together a mechanical speed controller.
Most trolling motors use a foot pedal that varies a resistance to control speed. No idea exactly how that thingy is put together, but there should be some way to use a servo to do that varying part. Might be a rather large servo, but still cheaper than an ESC rated for that kind of current handling!
Good luck!
- 'Doc
Pictures would be very nice!
(in reply to green-boat)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
Search |
