dStruct714
CA, USA Status: offline
Lol you said nipple, huh huh huh (butthead voice). Seriously though, I just went out and purchased an Ofna OFN10166 (large fuel filter), and OFN10168 (primer pump/filter) yesterday, I'll post some pics once I have the time. Yeah I would think the pressure in the tank would be much like a hydraulic piston/cylinder vs. pneumatic.. Air isn't very dense. So I mounted the filter on the middle of the rear shock tower with a zip tie (cause Dogman needs to machine me a bracket that would screw into those two screw holes in the rear shock tower, hint hint nudge nudge..), and the primer dealio I mounted on the front brake screw/post where my throttle return spring goes for a lack of a better place, but it twists slightly when I use the brakes.. I was thinking a good place to mount this primer would be the exhaust side handle/roll-bar, drill a hole to keep it from twisting around. Anyone know what size screw is used to mount the handle to the truck? Looks to be about a 3mm or so, I may run a tap through the hole. Any ideas on better mounting locations?
