RE: Bad luck with Magnum NX - Need help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> RE: Bad luck with Magnum NX - Need help
Page: <<   < prev  1 [2]
Login
RE: Bad luck with Magnum NX - Need help - 7/3/2007 10:02:48 PM
dStruct714
Status: offline
When it comes to antenna's and their signal characteristics it's actually not good if you fold it back on itself. For example you run the wire through the tube and then fold over 6 inches back over the outside of the tube and tape it down or something, you actually cancel out that section of wire by doing that.
What I did with my GST was ran the antenna through the tube and left about 1/2" stick out, folded that over the end and stuck the cap on, then I took a 1/2 or so piece of heat shrink tubing and carefully heating it around the cap to cover the wire, and stop my damn cap from popping off the when I'd remove the body.
I can run that thing really far away without any issues, as for the 2-3" of slack I made a nice neat loop so it comes out of the side of the receiver and folds under it, and then out the hole.
Hey burningpoo, you said box! oh wait so did I.. heheh box
(in reply to dustin7837)
       Post #: 26
RE: Bad luck with Magnum NX - Need help - 7/14/2007 5:29:35 PM
RobertMP
Status: offline
Finally had my Magnum NX out for a real spin and it was freaking awesome!
I have installed pretty much everything I had been told and the range is now 40 meters or so. Now exactly as much as expected, but still enough to make the car stretch it's legs.
(in reply to RobertMP)
       Post #: 27
RE: Bad luck with Magnum NX - Need help - 7/14/2007 9:43:48 PM
SOILWORK
Status: offline
Glad to hear that you have the problem solved, have fun!
_____________________________
Tnx Master www.cityparktrack.com
       Post #: 28
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.203RCU2
