Bad luck with Magnum NX - Need help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> Bad luck with Magnum NX - Need help
Page: [1] 2   next >   >>
Login
Bad luck with Magnum NX - Need help - 6/30/2007 9:04:22 AM
RobertMP
Status: offline
I recently purchased a Magnum NX but havn't had much luck with it.
It all started when I had to burn-in the engine. It was dead! The glow plug was dead and after a replacement it ran smooth.
After a few tanks of fuel had been consumed by the engine I started slowly moving the car around.
Now my real problems began!
When the car was +10 meters from me it went bezerk and I lost control of the car.
I shut the engine down and started testing. It became apparent that the radio range was less than 10 meters.
I went to my local shop and they told me to replace the reciever. So I bought a new reciever. Didn't help!
I then purchased some really good batteries to see if the problem was related to battery power. Still no luck!
I then contacted a friend and we tried using his batteries and crystals... Still no improvement in range.
You might think it's the transmitter by now. Well so did I, so I ran out and bought a new transmitter. Still no luck!
I have now replaced crystals, transmitter, reciever and installed 2500mA batteries and it's still less than 10 meter range.
I really need some help. The "ohh this is fun experience" is turning into frustration!
I could have bought the biggest CEN RC car instead of all the money I proured into my Magnum, just to get it to work and it's still not working!
Edit: Changed sender to transmitter
< Message edited by RobertMP -- 6/30/2007 12:11:49 PM >
       Post #: 1
RE: Bad luck with Magnum NX - Need help - 6/30/2007 9:27:17 AM
diggernz
Status: offline
maybe its the transmitter. transmitter batteries OK? some xtals dont work with some radio geat. Its best to stick to all the same make in each model if you can.
_____________________________
TB02-TT01-Brat- Blackfoot Extreme-MiniLST-HPI Sprint2-Kwada GT2-EMaxx-TerraCrusher--Academy STR4_many other projects
(in reply to RobertMP)
       Post #: 2
RE: Bad luck with Magnum NX - Need help - 6/30/2007 9:29:32 AM
RobertMP
Status: offline
woops. I named the transmitter the sender..
Other than that. I also installed the 2500mA batteries in the transmitter
(in reply to diggernz)
       Post #: 3
RE: Bad luck with Magnum NX - Need help - 6/30/2007 1:47:25 PM
SOILWORK
Status: offline
Check the servos...they could be glitching.
Tnx Master www.cityparktrack.com
       Post #: 4
RE: Bad luck with Magnum NX - Need help - 6/30/2007 2:36:54 PM
RobertMP
Status: offline
"glitching". Can you please explain what that is and how to test it?
(in reply to SOILWORK)
       Post #: 5
RE: Bad luck with Magnum NX - Need help - 6/30/2007 4:42:58 PM
SOILWORK
Status: offline
Put the truck on a stand and keep the transmitter off but turn on the reciever and move the servo wires and battery wires and see if the servos twitch. If there is twitching, use heat shrink tubing around the wires to help insulate from interference. This happened to my Nemesis, the battery wire was causing interference with the throttle servo and it would lock at wot. Somtimes it could be a simple thing as a couple of wires being to close together or if the wires are close to a metal component such as the throttle or brake linkage..I hope this is some help.
       Post #: 6
RE: Bad luck with Magnum NX - Need help - 6/30/2007 5:04:06 PM
RobertMP
Status: offline
I will try that tonight!
Thx a lot for the info from your experiences.
I apriciate all the info I can get
       Post #: 7
RE: Bad luck with Magnum NX - Need help - 6/30/2007 5:35:59 PM
SOILWORK
Status: offline
I forgot to add that somtimes, nitro engines when running can also cause some interference.
       Post #: 8
RE: Bad luck with Magnum NX - Need help - 6/30/2007 8:18:37 PM
RobertMP
Status: offline
Ehh and how am I supposed to prevent that from giving me bad signal reception?
       Post #: 9
RE: Bad luck with Magnum NX - Need help - 6/30/2007 8:39:01 PM
SOILWORK
Status: offline
Insulate the wires with heat shrink, you have to experiment with the placement of all the wiring. Like I said before servo glitching can be caused by the wires being to close to something electrical ar metal. Once you find a setup with no interference, secure the wires down so they dont move around when driving over rough terrain. This is a problem with a simple fix if it is your servo glitching.
       Post #: 10
RE: Bad luck with Magnum NX - Need help - 6/30/2007 9:25:34 PM
derrick05
Status: offline
Did you cut the antenna wire?
       Post #: 11
RE: Bad luck with Magnum NX - Need help - 6/30/2007 10:41:19 PM
RobertMP
Status: offline
Nope. I did not cut it. But it is very long compared to the plastic tube which is on the car. It hangs out as far as it can without any danger of getting in the wheels. The rest is folded in the battery casing.
(in reply to derrick05)
       Post #: 12
RE: Bad luck with Magnum NX - Need help - 7/1/2007 4:13:36 PM
derrick05
Status: offline
Try alkaline batteries in the remote and see what happens.You say you have 2500 rechargables.If they were new,on their first charge,then the batteries arent doing their job.It takes at least two charges to properly cycle new rechargable batteries.The first charge,straight out of the pack will provide you with less than half power.It isnt until you run that charge out and recharge, that you will start to see the real power of the batteries.
       Post #: 13
RE: Bad luck with Magnum NX - Need help - 7/1/2007 5:10:38 PM
Hordsak
Status: offline
I wonder if having the antenna wire folded up in the box could be causing something. I would try un-folding the wire, and extend it fully out the tube. If it's really long, twist it around the tube.
       Post #: 14
RE: Bad luck with Magnum NX - Need help - 7/1/2007 5:21:02 PM
The Real Dogman
Status: offline
Hey hordsak, you beat me to it, I just saw this thread last night and thought this morning. Well you are right if you have wad of wires that are powered you will naturally create Electro magnetic frequencies and your antenna being waded up in that mess it will pick up those frequencies.. So good call hardsak!!
Robert your antenna wire all the out of the tube let it hang down the antenna tube then slip a 1/4" peice of fuel tube over it to keep it under control.
Good luck!!!
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Matrix Arena/Wheely King Tuber/Axial Co
(in reply to Hordsak)
       Post #: 15
RE: Bad luck with Magnum NX - Need help - 7/2/2007 4:41:34 AM
rolland
Status: offline
I would also suggest using alkaline battery's in the TX. Rechargables have a lower voltage than regular alkalines it doesn't matter how many times you cycle them the voltage will always be lower.
rolland
(in reply to The Real Dogman)
       Post #: 16
RE: Bad luck with Magnum NX - Need help - 7/2/2007 8:08:22 AM
RobertMP
Status: offline
I have an additional question, which I am not sure is related to my problems or a "feature"
When I give the throttle full speed and pull the brake fast, the servo just goes to neutral.
But if I relase the throttle and keep it at neutral for 0,5 seconds or more and then pull the brake it actually brakes.
I find that a bit odd and it often leaves me with a car that doesn't break when I want it to.
This is not related to the range between transmitter and reciever. This occurs even within cemtimers between transmitter and reciever.
(in reply to rolland)
