Motorboy
Ugo... quote:
Diesel motor oils have strong additives contrasting acidity, castor and ordinary motor oil have not. So this can lead to some corrosion. >> Again your assertion. I has repaired a lot of vehicle diesel engines, never experienced rust inside the engine, too not in heavy truck engine who my father are working as truck driver and keep maintenance self at truck....." Here is another proof that you lie when affirm to be a diesel mechanic. You don't know ever that diesel engines use diesel motor oil, so they don't wear from acidity. DIESEL OILS HAVE THE HIGHEST CONTAINT OF ACID CONTRASTING ADDITIVES . this contrasts the high acidity of diesel combustion residuals entering into the oil. This is one of the main differences between a diesel and a spark engine motor oil. Of course there are other peculiar additives everyone dealing with diesel knows. Motoroil are not only motoroil. I am writing short and simple since i am not writing in more detailed addidives etc in motoroil.. here: In light road vehicle are same motoroil used in both petrol- and diesel engine since there are not enough sulfur in autodiesel. See in car manual or workbok for car mechanics for oil products where API and ACEA code are wrote for the engine. See at the oil flask with API and ACEA code for both petrol- and diesel engines. The Peugeot cars with petrol- or diesel engine are using same oil where the ACEA code are marked in car manual. Some light road vehicle who has tuned engine need better oil quality, higher viscosity. The oil for bus/truck has additives against load and the light vehicle motoroil can not be used in the engine who are designed for bus/truck use cause engine will be wrecked. And reverse the oil for bus/truck can use in light vehicle with diesel engine without problem. Viscosity are same in both oils for light road vehicle and bus/truck, but difference in load properties. The clima zone are influencing at the oil and need oil with right viscosity adapted for the engine where you live and are driving the vehicle. In heavy ship engine are the motoroil difference from road vehicle motor oil, the oil calculated for heavy ship has very high alkaline or base addidive to neutralize the acids products from combustion cause the heavy oil are used as fuel who has high sulfur who are damaging the cylinder in heavy ship engine. The oil for cylinder and crankcase are separated each other to prevent acids are coming into crankcase and erroding the bearings. If the heavy ship engine are using the light oil as fuel, there are not neccesary to use oil with alkaline or base additive since there are not enough acids products from combustion. You are still writing "Maybe" and "why not".. I has used both autodiesel, kerosene and charcoal lighter fluid and has do not have problem with carbon residues in the model dieselengines. No, Barbeque igniter does not have lower boiling temperature than kerosene, little to compare between fuels. Here are the technical data from our norwegian oil company Statoil... Kerosene: Self ignition temperature: 200 °C Boiling point: 192 - 245 °C Viscosity: 2,07 cSt / 25 °C Barbeque igniter: Self ignition temperature: 200-250 °C Boiling point: 240 °C Viscosity: 7 cSt / 25 °C Diesel: Self ignition temperature: 220 °C Boiling point: 165 - 360 °C Viscosity: 2.6 mm²/s 40°C Cetane number: about 50-55 Do not forget, we are loaning the world of our children.. Will it be profitable to use turpentine when we must care the wood against exterminating with cainsaw and axe?? The pine tree will use 70 year to crow until the tree are tall enough before the tree are ready to use. Turpentine (also called spirit of turpentine, oil of turpentine, wood turpentine, gum turpentine) is a fluid obtained by the distillation of resin obtained from trees, mainly pine trees. Now it is time to stop in this forum!
< Message edited by blw -- 8/14/2007 3:06:42 AM >
_____________________________
Jens Eirik All landings are just controlled crashes!
