pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
Ugo, you are dead wrong in your assumption that car diesel is better because of it's better cetane number. In my tests, the car diesel was the worst fuel I tested, despite better oiliness and controlled cetane number. It also is the fuel with the highest flash point of the fuels tested. We all know, that a small venturi works wonders. I know that a larger venturi gives a lot more power, but at expense of very critical adjustment. By changing the spray bar system alone, vast improvements can be achieved. So it seems to boil down to creating as fine a fuel mist as possible. The finer the mist, the less fuel is expelled out of the exhaust in unburnt state. During combustion, there is only a limited amount of time available in wich the kero droplets can evaporate and then ignite. As they burn, further evaporation takes place. If the droplets are too large, the core will never reach the combustion state before all oxygen is used up, and the engine will use more fuel than needed. That also is the reason that more ether will provide better power. It will evaporate faster, so the combustion process can take advantage of the wider explosion limits, and thus more ether can burn with the same amount of air and generate more usable BTU's for the engine to transfer into work. (fuel:air ratio is 1:8 for ether, 1:14 for kero) Even though previous tests with the double venturi carb has been used with glow engines, it shows that a finer fuel mist in those engines also very much reduced fuel consumption. We seem to compensate lack of atomisation properties in the carb by allowing more fuel in, so that the part of the fuel that dit atomize properly can burn. Do not go on the path of redifining atomisation. The process means creating a fine aerosol of fuel particles suspended in the induced air, and not breaking down in atoms you tried us to believe in earlier posts. The same principle applies to diesel engines.
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl There is sanctuary in analisys.
