pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
quote:
ORIGINAL: merugo Greg, who burns first stoles the oxygen. I cannot give here a course but the mechanism of improving the combustion is a mechanism of frontier, if one runs faster he can lead and drag others, so all run better, but if three run too fast, no room for others on the podium, so no competition. It is difficult to demolish longstanding commonplaces, but I see for the first time someone admitting the simple truth that ignition improvers do NOT give oxygen. On the contrary they suck, and if you exceed with them they leave a short trail too poor of oxygen, so depriming the combustion. Stewart, all usa modelers here use 2-ethylexylnitrate, aka octyil nitrate! If you use amyl nitrite, not too much consolation, since two molecules of amyl nitrite Csub5Hsub11NOsub2 SUBTRACT 31 atoms of oxygen from your engine for burning completely. Ugo Ugo, There are different schools of thinking. The other way is in my way of thinking more logical, as here explained: first the C5H11NO2 in your formula decomposes by the high pressure and heat, and liberates the two Oxygen atoms in highly active state, not as a gas, but as ions in a plasma. That is what NOx's do. They then do not steal from the flame front which is not yet there, but help to initiate, and propagate the ether combustion with subsequent petroleum aerosol combustion for which the other C5 and H11 parts now are partners, albeit in a more active state than the C's and H's in the ether and petroleum mix, which still are in a gaseous state. This way, if too much improver is present, pressure rise during combustion will be too fast. This causes knock symptoms, and the compression has to be reduced. ( I can confirm this from my not very scientific tests). Think about this a moment. The result is more in line with experience than your explanation.
< Message edited by pe reivers -- 9/15/2007 10:10:01 PM >
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl There is sanctuary in analisys.
