ICU-L Led code
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> ICU-L Led code
Page: [1]
Login
ICU-L Led code - 6/30/2007 11:56:14 AM
snys
Status: offline
Hi,
What does it mean if the LED on the ICU-L ignition stays lit after switching on? The manual shows only two codes, (Ok, or battery dead)
but not what it means if the LED stays lit.
Thanks!
Sny.
       Post #: 1
RE: ICU-L Led code - 6/30/2007 1:20:38 PM
BaldEagel
Status: offline
My manual shows three codes:
Fast blinking after power up = battery test running
Fast blinking (5 seconds after power up = battery voltage low
One short flash persecond= sleep mode.
I have the original instruction sheet and the new one available on Pe's web site and neither mention the LED on permanatly state. Sorry not to be any help on this.
Mike
EDIT: just thought of one other place I can check, hold on.
_____________________________
No matter what anyone says 100% is the maximum you can get.
(in reply to snys)
       Post #: 2
RE: ICU-L Led code - 6/30/2007 1:25:12 PM
BaldEagel
Status: offline
Nope sorry, I thought I would check the Evolution manual just in case, but it does not mention this state either, I am sure that Pe or someone will come back with a reason after the week-end.
Good Luck
Mike
(in reply to BaldEagel)
       Post #: 3
RE: ICU-L Led code - 6/30/2007 4:11:26 PM
snys
Status: offline
Thanks Mike.
After the last run I just switched it off as usual, and today I have this problem. I hope it is not serious.
       Post #: 4
RE: ICU-L Led code - 7/3/2007 3:40:16 PM
snys
Status: offline
MSR Engines or whatever does not know what it means either. They are sending a replacement ignition.
Nobody else has ever experienced this?
I was thinking of buying the 45cc, but now I am a bit worried.
(in reply to snys)
       Post #: 5
RE: ICU-L Led code - 7/3/2007 5:35:08 PM
BaldEagel
Status: offline
Don't be concerned about the 45 its the most powerful 43cc engine out there, on par with the DA50 IMO the 58 Pro is even better, my 45 is in a 2M Extra and the 58 is in a QQ 85" Yak, can't fault them, the only problems I have had have been of my own making.
Mike
(in reply to snys)
       Post #: 6
RE: ICU-L Led code - 7/9/2007 2:50:15 PM
janch
Status: offline
C onnect LED indicator to the ignition box (red/black wire to “+”).
U sing the included connector, plug your battery pack into the ignition box.
F ive seconds after connecting the bat¬tery, the LED indicator should go out. If the LED is blinking after you connect the battery, the battery’s voltage is too low.LED
(in reply to snys)
       Post #: 7
RE: ICU-L Led code - 7/11/2007 6:42:02 PM
snys
Status: offline
janch:
Neither happens. The LED just stays on forever. It does not blink, and it does not go out either.
(in reply to janch)
       Post #: 8
RE: ICU-L Led code - 7/11/2007 7:04:01 PM
pe reivers
Status: offline
The light on all the time is not a standard code. Does the engine still run properly?
The ignition may need to be replaced.
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to snys)
       Post #: 9
RE: ICU-L Led code - 7/16/2007 6:40:28 PM
snys
Status: offline
My supplier changed the ignition for me.
Thanks!
(in reply to pe reivers)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU5
