hlhamner
TX, USA Status: offline
Big Bird, Just got back from flying my Twist 40 (GY401 gyro installed) and Showtime 90 (G500A JR rate gyro installed) and I tried the Heading hold mode on the GY401 for take offs and I had similar results. First take off was into about an 8-10 mph wind with throttle slowly and cautiously being fed in until take off. The take off was straight with no surprises. I am running about 80% gain in AVCS (HH) mode. Then, the next takeoff was into a direct cross wind in HH mode and I was ready with the ailerons and the gyro switch. I punched full throttle and again, take off with a direct cross wind was very straight with no surprises. I love taking off with this gyro. Okay, now for the fun stuff and the real reason I installed the GY401 gyro. Flying about 20 ft above ground in my Twist 40 I switched to 3D rates and then switched from normal gyro mode to heading hold mode and pulled up into a Wall. Apply some power and the little, short moment, Twist, hovered like it was being help by an invisible string from above. The wind was blowing so it looked pretty cool to see it hover 30 ft above ground moving across the field. Torque rolls are now much easier - just need to keep the elevator movements straight and hold some left aileron to help the torque. Again, I love the GY401 for airplanes. I wish I had done this sooner. I highly recommend the GY401 gyro for use in airplane takeoffs if needed and especially if you are into 3D. I didn't have time to try it but I'll bet this will make waterfalls much easier if the stall is entered in heading hold mode. The only disadvantage I see so far in using the GY401 gyro is that your dual or triple rates don't work on the gyro channel which, in my case, is the rudder. Everything, even in normal mode, is at the high rate so I used lots of expo, like 75%, on the lo rate switch side. Unless I find the answer for this I would not use the gyro if you have rudder mixed with ailerons to get a coordinated turn on a larger or scale model. It just may give you the opposite of what you expect. Do you know how to totally disable the GY401 in flight so the dual rates will work as you would expect? Hank
