BarracudaHockey
Joined: 7/13/2003 From: Orange Park, FL, USA Status: online
The gyro will take 6v, the tail rotor servos wont, not at high frame rate in any case. We use .7v step downs to the servos with 6 volt systems all the time in helis, though the majority of us with higher end helis run 8 volt lithum packs with regulators. As for dual rates its important to understand the concept that the end points on the rudder channel have no effect on total servo throw, thats set by the limit on the gyro. In helicopters that end point sets the rate at which the nose will turn. So if you reduce the end point the gyro will command a yaw (piroette) at a given rate, if the winds blowing this will allow the gyro more throw to maintain that piro rate. I suspect but dont know for sure without testing, that low rate on the rudder would have the same effect on an airplane, less rudder throw for less turn rate but it may not be immediately obvious on the bench I would experement with say 10 percent changes at a time. As for the gain, 100 percent end point is 100 percent gain, going farther does nothing. If you have the 9C super LMK and I'll tell you how to use the GYRO SENS screen to your best advantage and that way theres no question what gain you are running as its WYSIWYG when properly setup.
< Message edited by BarracudaHockey -- 8/28/2007 7:13:01 PM >
_____________________________
Andy - Helicopter Forum Moderator AMA 77227 http://www.jaxrc.com
