BarracudaHockey
Joined: 7/13/2003 From: Orange Park, FL, USA Status: offline
No problem. On a heli, the end points control how fast the gyro will let the helicopter piro. Its called a yaw rate demand gyro, and by setting the end points you can customize how fast the helicopter will spin about its main rotor axis. I run into this all the time where people turn down the atv's to adjust the throw and end up with all sorts of strange behavior. Flavio, another thing, you probably want to run your rate mode gain up to about 5 or 6 percent. That area around mid throw is really a dead mans land, from 0 to 3 or 4 percent, and as I said, start small and work your way up with the gain in heading hold.
_____________________________
Andy - Helicopter Forum Moderator AMA 77227 http://www.jaxrc.com
