Big_Bird
Joined: 12/18/2001 From: Arlington, TX, USA Status: offline
quote:
ORIGINAL: BarracudaHockey Thats why. You limit the servo throw with the limit pot on the gyro and set the end points out towards 100 or so. You would set your linkage up so that it limit pot is in the vacinity of 100 as well. If its working for you, don't mess with it but that is why you're seeing that behavior. Andy, thanks a lot for your help. That totally corrected the problem. It was not necessary to re-do any linkages. The gyro has total control of the throw even in the off position. I set the ATV (end points) at 100/100. With the gyro pot at 100 the overall throw of the rudder was the same as it was with the end points set at 45/45. Now, with the end points set at 100/100, when I do the waggle 3x in HH mode the gyro always resets the rudder to neutral. It's sure nice to run across a true expert.
_____________________________
Ken WACO Brotherhood #70
