Tube fitting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Tube fitting
Page: [1]
Login
Tube fitting - 7/1/2007 2:30:59 PM
ytrewq
Status: offline
Hi,
Help. Is there any way to temporarily soften gas, air and fuel tube to make it easier to fit onto nipples. I suffer with weak wrists and am having great problems fitting out my latest model, especially when working inside the fuselage for example.
Alan
       Post #: 1
RE: Tube fitting - 7/1/2007 2:34:48 PM
Harley Condra
Status: offline
Warm it with a heat gun just enough to allow it to slip over the fitting barb.
You can wipe a small amount of Vaseline on the fitting to reduce the friction.
Harley Condra
BVM REP
JetCat REP
_____________________________
Harley Condra
BVM REP, JetCat REP
(in reply to ytrewq)
       Post #: 2
RE: Tube fitting - 7/1/2007 9:51:50 PM
bcovish
Status: offline
Instead of using vasoline, I use CA kicker and spray on both parts. Slides on easy and evaporates in a little while.
Bob-O
Austin TX
(in reply to Harley Condra)
       Post #: 3
RE: Tube fitting - 7/2/2007 12:27:38 AM
SinCityJets
Status: offline
Yah, I would avoid vaseline.
Sin City Jet''s Rally 2008 November 7-9
http://www.sincityjets.com/events.htm
(in reply to bcovish)
       Post #: 4
RE: Tube fitting - 7/2/2007 3:44:00 AM
joeflyer
Status: offline
Stick the end of the tube in your mouth and chew on it a few times. The moisture, warmth, and chewing temporarily softens the end. Also a little bit of saliva reduces the friction.
Joe
(in reply to SinCityJets)
       Post #: 5
RE: Tube fitting - 7/2/2007 9:04:19 AM
j.duncker
Status: offline
Find your pointy nose pliars.
Push the tube on to the pliars and heat it up at the same time. Boiling water will do.
Now open the pliars to stretch the tube.
Works for me.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
(in reply to joeflyer)
       Post #: 6
RE: Tube fitting - 7/2/2007 3:52:02 PM
RAMFlyer
Status: offline
I use the old orange handle "ice pick" that Byron used to include in their kits. Heat it up by laying the tip on a monokote iron set at 350 degrees, push it into the end of the tubing and leave it there for 10 seconds. After putting the tubing over the nipple I wait at least 5 minutes for the tubing to cool down and then safety wire everything.
For larger tubing I use an awl the same way.
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU5
