RE: OS 200
Tower Hobbies
Logged in as Guest
Users viewing this topic: DLEVETT
  Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: OS 200
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: OS 200 - 7/31/2007 6:39:19 PM
Hans Meij
Status: offline
Today bench run 10% nitro
APC 16*12 7900
APC 16*13 7700
Engel 18*11 7500 (Engel 18*11 is a narrow bladed carbon prop)
Conclusion for now. Not such a great engine.
My laser 200 V-twin did on the same day with the same fuel on these props 200rpm more.
(in reply to alfredbmor)
       Post #: 76
RE: OS 200 - 7/31/2007 6:42:04 PM
Rate1
Status: offline
Hans,
What is the weight and price of the Laser 200 V-twin?
_____________________________
<--- This is my dog, Capt Morgan, and he has propably more flight hours than you.
(in reply to Hans Meij)
       Post #: 77
RE: OS 200 - 7/31/2007 6:47:52 PM
Hans Meij
Status: offline
quote:
ORIGINAL: Rate1
460 pounds and 1230gr mufflers included.
(in reply to Rate1)
       Post #: 78
RE: OS 200 - 7/31/2007 6:59:57 PM
Rate1
Status: offline
that is about US$950... Then I rather go for the OS 200FI instead...
       Post #: 79
RE: OS 200 - 7/31/2007 7:19:52 PM
Hans Meij
Status: offline
quote:
ORIGINAL: Rate1
Sorry, but that is not the point. It is not that the laser is a better buy.
I only expected a single to do better (power-wise) then a v-twin with the same displacement.
It did not, and that is my disappointment. I hoped this engine would be a inexpensive alternative for a engien in a pattern ship, but it is not up to that task.
(in reply to Rate1)
       Post #: 80
RE: OS 200 - 7/31/2007 7:25:24 PM
Rate1
Status: offline
Hans,
Myself are looking for an engine to my 25% Extra, flying weight guestimate 11 lbs. It's Laniers old full build kit so it is not a 3D plane. However I have made several weight reduction steps and are looking for an engine that is low on nitro (expensive in Europe as you know) and will give it rocket performance.
You have this all new engine at hands, do you think it is a good choise for my application, or do you recomend me to go for YS 160/170 instead?
       Post #: 81
RE: OS 200 - 7/31/2007 7:30:47 PM
Hans Meij
Status: offline
Sorry hit the wrong key. And now the door-bell rings. Be back soon
This one I expect.
http://www.lanierrc.com/lrcprivate/rcairplanes/extra25percent.htm
Rocket & low on nitro & low weight to keep it flying well. I think the saito180 and this OS200 are still the best options.
YS will be more rocket like, but if this will be your more ten ten fligths per weekend ship the fuel costs will be not what you like.
< Message edited by Hans Meij -- 7/31/2007 8:54:30 PM >
       Post #: 82
RE: OS 200 - 7/31/2007 10:11:43 PM
blw
Status: offline
Or maybe the Saito 2.20. It will probably run fine on 5% fuel like the other Saitos.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
       Post #: 83
RE: OS 200 - 7/31/2007 10:57:25 PM
Rate1
Status: offline
Thanks for the advice.
Yes that is the kit I am building.
High nitro fuel is both a hustle as I would need to mix it myself as well as it is expensive in Europe. This is the reason why I am hoping for good reviews on the OS 200. Obviously the OS200FI would be great but I will never pay that price.
The Saito 220 is too heavy. I am trying to keep the wing load light.
< Message edited by Rate1 -- 7/31/2007 11:00:01 PM >
(in reply to blw)
       Post #: 84
RE: OS 200 - 8/1/2007 1:36:06 PM
RadarController
Status: offline
i'm in the same boat as you. about 11 pound plane. like the sound/torque of a four. wieghs 1.5lbs less then the gas. more torque then the 1.60. but not near the hp as a gas. its just that weight. with the glow i can put redundancy stuff in my plane and not worry about weight. wouldn't be talking about this if i would have got the yak. wing loading is rated a lot higher. so i'm in a dilema.
(in reply to Rate1)
       Post #: 85
RE: OS 200 - 8/1/2007 2:02:44 PM
Flyer95
Status: offline
Saito220, 180 or OS200 should all give excellent performance for that size and weight but must be used with the correct prop size.
They dont like to be loaded down to 7500rpm at peak like a 50cc gasser. At +8500rpm and they should pull these planes like rockets.
These are the props I would use for good performance with that size fourstroke glow engines 17x8, 18x6, 18x8 or 19x8 for the 220.
(in reply to RadarController)
       Post #: 86
RE: OS 200 - 8/2/2007 2:03:55 PM
PlaneKrazee
Status: offline
Hans,
How does the OS160FX compare on those APC props you ran? I am only familiar with APC 18X6W and 18X8W rpm values. I am looking to get an idea of the power comparision between those two engines.
There was a website dedicated to pattern engine setups, props, pipes, and rpm data but I have either lost the website or it has been deleted.
KB1DTB
AMA11123
       Post #: 87
RE: OS 200 - 8/2/2007 2:56:20 PM
RadarController
Status: offline
from what i've read.. they're very close. however.. i would think the two stroke needs to spool up to get the horsepower. midrange power might suffer briefly. the four stroke can throw larger props. the tachs taken on the 200 show that it can throw an 18x8 at the same rpm as what the 1.60 thows a 16x8. the tachs also show... if you throw a 16x8 on the 200.. it gets up close to 9000rpm. 8400's with an 18x8. 1.60 plus a pitts costs 330. and weighs 32.8 without muffler. probably about 35.8ish with. the 200 weighs 30.7 with stock muffler. which seems to be very manipulative. and you get four stroke sound.. ease of use after break in. usually no needle valve adjustments etc. i'm leaning towards the 200 if i don't go with a gas.
< Message edited by RadarController -- 8/2/2007 3:25:29 PM >
(in reply to PlaneKrazee)
       Post #: 88
RE: OS 200 - 8/2/2007 5:09:20 PM
Hans Meij
Status: offline
quote:
Hans, How does the OS160FX compare on those APC props you ran?
I have a well piped (KS1025) 160FX on a pattern ship too. The two stroke does about the same as the laser on the ground, but can handle a bigger (in this case a 17*12 APC) better than the laser can. The laser does a bit better in rpm with the 16 inch APC's.
In horizontal flight the 160FX speeds up very wel and there I like the characteristics of the piped 2 stroke better. The dynamics of the plane look better. However if the climb rate is more than 45 degrees the Laser is performing better because there is never a rpm change up or down. Downlines with a 4 stroke are a lot better because of the breaking.
The OS200 I only tried it bench running. To me the power was disappointing however it only has seen two tanks of fuel. A well piped FX160 will do better then the OS200. A muffled FX160 will not do better then the OS200
< Message edited by Hans Meij -- 8/2/2007 5:11:23 PM >
       Post #: 89
RE: OS 200 - 8/2/2007 5:53:26 PM
RadarController
Status: offline
if i used the 160 i would be using a pitts. i want hover and pull out performance. what's your thoughts.
       Post #: 90
RE: OS 200 - 8/3/2007 3:30:09 PM
PlaneKrazee
Status: offline
Hans,
Thank you for the reply. It sounds like the 200 is a winner if it can spin a 18X6W or 18X8W at a higher rpm than the 160FX especially considering the weight reduction compared to the much heavier Saito 2.20.
I'm still very interested in the fuel consumption of the 200 compared to the 160FX, one of the most fuel effecient engines I have ever used.
If the 200 can spin a APC 17X8W @ 9200 rpm on 5% nitro and run for 5 minutes 20 seconds it will be on par.
KB1DTB
AMA11123
       Post #: 91
RE: OS 200 - 8/14/2007 1:56:16 AM
