RE: OS 200
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: OS 200
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: OS 200 - 8/17/2007 6:05:19 AM
wingburner
Status: offline
Rate1,
Not sure on the tank size as it came with the plane...It looks to be about 14oz....I don't keep track of the time but i'm sure i've flown at least 10 minutes of a mixed bag of flying and still had a 1/3 of a tank left.It seems to be a miser on fuel if a guy doesn't fly flat out all the time..
(in reply to Rate1)
       Post #: 101
RE: OS 200 - 8/31/2007 10:59:42 PM
Rate1
Status: offline
I have now placed an order on this engine. What I gather a 18x8 prop is the optimum for it. I was kind of hoping for a 19x8 wich I might give a try after been properly runned in.
_____________________________
<--- This is my dog, Capt Morgan, and he has propably more flight hours than you.
(in reply to wingburner)
       Post #: 102
RE: OS 200 - 2/11/2008 6:40:41 AM
PlaneKrazee
Status: offline
Anyone else shell out the clams for this engine?
KB1DTB
AMA11123
(in reply to Rate1)
       Post #: 103
RE: OS 200 - 2/11/2008 7:01:33 AM
rcdude7
Status: offline
Nope, I bought a moki 2.10 instead, not because it's a better engine, it's just that It was almost 200 clams short of the 2.0fs.
I'm sure the 2.0fs sounds better.
(in reply to PlaneKrazee)
       Post #: 104
RE: OS 200 - 3/29/2008 1:10:17 PM
Texan
Status: offline
Rate1,
Now that you have spent some time with the OS 200, do you have any comments on its performance?
(in reply to Rate1)
       Post #: 105
RE: OS 200 - 3/29/2008 3:51:17 PM
DLEVETT
Status: offline
I,m picking up an EF Yak 74" at Toledo, I,ve got a Saito 220 waiting for it but if that combo comes out heavy I,m going with the OS 200-Pumped version.
You can,t beat the power and sound of a large 4 stroke glow engine in planes under 13lbs IMHO.
Dave
(in reply to Texan)
       Post #: 106
RE: OS 200 - 3/30/2008 7:00:40 PM
Rate1
Status: offline
Texan, I still havn't flown with it. My build came to a stop whan I got a new job. I am now struggeling to find some spare time to finish my build and to try out this engine.
(in reply to DLEVETT)
       Post #: 107
RE: OS 200 - 5/3/2008 1:10:44 PM
tigil
Status: offline
Here I made a bench test with the 200 FS w a 18X8 APC prop . You can see the tach reading with this prop on youtube you can find it with this tag ''OS 200''
i
(in reply to Rate1)
       Post #: 108
RE: OS 200 - 5/3/2008 4:20:30 PM
tigil
Status: offline
here is the link http://media.putfile.com/OS-200-Tach-Test
(in reply to tigil)
       Post #: 109
RE: OS 200 - 5/4/2008 8:46:03 AM
Flyer95
Status: offline
tigil, Is it the standard 18x8 or the 18x8W you have on the OS200?
(in reply to tigil)
       Post #: 110
RE: OS 200 - 5/4/2008 11:47:22 AM
PlaneKrazee
Status: offline
I have to ask the same question, wide blade or regular? Did you have the wing off or the engine rich to shake the fuselage like that?
KB1DTB
AMA11123
(in reply to Flyer95)
       Post #: 111
RE: OS 200 - 5/4/2008 1:38:12 PM
tigil
Status: offline
The wings on but the prop is not balanced and after the tach test I put the prop on the Dubro balancer to see w happen the prop seem to be ok at horizontal but at the vertical it need to grind the hub 1/4 inch to be ok ,just check the picture
Click to see fullsize image.
Click for fullsize
       Post #: 112
RE: OS 200 - 5/5/2008 1:32:09 AM
PlaneKrazee
Status: offline
That's the 18X8 regular/narrow blade.
KB1DTB
AMA11123
(in reply to tigil)
       Post #: 113
RE: OS 200 - 6/5/2008 1:44:59 PM
TOLSOF
Status: offline
ok guys.
thats my story from greece.
i run this engine on my qq yak 54 73" with a 18-6w apc prop.
as a result the engine runs grate on the ground but... on the air at full throtlle it kind of misses or stals or sounds like running too lean.
ok. i take it down to the ground turning the needle to enrich the mixture and on the air again. result...not enough power.
running a 20-6 wooden prop, elliminates the problem but climbing is redused.
trying different fuels (nitro percentage) did not notice any diference.
on the ground 18-6w showed 8400 and 20-6 showed 7400 rpm.
i just can not get the power out of this engine.
do you think i should try a 18-8 prop??? since 18-6 (in my opinion) causes the float valve faenomenon.
helpppppppp.......
by the way what is the valve clearance for this engine since there is no reference in the manual??
i have to admit one thing....... idle is the best i have ever experinced in a 4 stroke engine.....just great.
       Post #: 114
RE: OS 200 - 6/14/2008 8:21:02 PM
John Serjeant
Status: offline
Question re the OS 200s.
Can one use (if you wanted to) os exhaust extensions, mufflers withis engine?.
Is the exhaust outlet threads the same as the 120 surpass series?.
I note that the 200 has a quite different muffler and short connector.
Also, note that OS have now brought out a a 200s with a pump.
Anyone managed to get one of these yet?.
John Serjeant
(in reply to TOLSOF)
