Strykaas
Joined: 3/21/2003 From: Paris, FRANCE Status: offline
quote:
ORIGINAL: John Serjeant I may have posted this elsewhere on this forum, but just in case it's not seen, my comments, so far on the )S 200. I very recently purchased an OS 200 s pumped engine. I soon made some comparisons with the )S 120 pumped engine of which I have two. Now, first thing is that the OS 200 doesn't fit on the OS aluminium mount for a 120, the bolts holes and crankcase dimensions are the same, but the OS 200 is about 3mm longer and the pump housing butts up right on the rear of the engine mount. Oh dear! The muffler/silencer is quite large; certainly much larger than I thought it would be; no doubt it will be effective. However, can foresee problems; especially for those (and me!) who will want to use this engine in scale/cowl configaration; particularly in an inverted position mounting. In my opinion, the way the muffler mounts and its size may well prevent it being enclosed by a cowl; unless it's large! So far, O.S. engines do not provide ANY after market exhaust/muffler/ extensions/pipes for this engine. None of the current O.S. accessories will fit the OS 200. Would be interested IF any of current OS 200 owners have found an alternative exhaust mounting option?. Hi ! I don't want to make any kind of ad here, but the well known rc engine store "JustEngine" in the UK can build any kind of exhaust system to you for a very attractive price compared to what you have put into your OS200. I haven't dealt with them since the death of Paul (founder and owner) but I bet they still provide very good service and support. You can contact them by email, they are quite responsive. Sometimes their welder is on holidays which can make ordering delay a bit longer but it might be worth the wait. http://www.justengines.unseen.org/
_____________________________
ProBro #2077 http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
