jcervantes11
CA, USA Status: offline
Hello, i have a rotofly which i had it for a while but haven't used it that much. But anyways when its off the ground, it rubble around and then loose control, what would cause this? When the blade is spinning on the ground, its ok, its until i am in the air. Even if I add even more power, nope it just roubble and loose control. What should i do??
_____________________________
Jim Cervantes, California USA
