RE: New CMP Cessna 182 .52 size
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: New CMP Cessna 182 .52 size
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: New CMP Cessna 182 .52 size - 8/13/2007 3:58:11 AM
sdcranford
Status: offline
I recieved mine on Sat, thank you FedEx. I wish Tower used FedEx, it showed scheduled for delivery on this comming Tuesday, my wife and I show up after a day running around and there is a big box on the front porch.
I opened it and looks like a well built aircraft. I have not had a fiberglass fuse before and I really like it. I like the molded in doors, and the vert stab is built in. I have a GP Fabric Cub to finish (just got the robart scale landing gear on it), ready for radio, hinging, and final assembly. Looks like a straight forward assebly even thought the manual is not really clear.
How has everybody done the split elevators? I have an idea but would like to hear other ideas. I am glad they are split as I really dislike the "joiner wire".
I am glad for the plug in wings, I am tired of the one piece wings. Also looking forward to hearing if anybody has put in the Robart Oleo on the nosegear!
(in reply to opjose)
       Post #: 51
RE: New CMP Cessna 182 .52 size - 8/13/2007 4:30:48 AM
Tracon
Status: offline
1 For Wheels
1 For Floats
1 For Spare Parts !!!
Sam
www.teamtracon.com
(in reply to sdcranford)
       Post #: 52
RE: New CMP Cessna 182 .52 size - 8/13/2007 5:23:25 AM
VFR_RC
Status: offline
well i am almost finished and just encountered an issue. The windshield will not fit, the top is about 3/8 smaller (width) than the top part of the fuse where the windshield is supposed to go.
Pic
Click to see fullsize image.
Click for fullsize
(in reply to Tracon)
       Post #: 53
RE: New CMP Cessna 182 .52 size - 8/13/2007 2:37:34 PM
Tracon
Status: offline
I don't think you cut it right, the bottom of the windshield is supposed to go into the grove behind the two red trim lines...
Did you leave the white trim line on the clear plastic windshield ???
(in reply to VFR_RC)
       Post #: 54
RE: New CMP Cessna 182 .52 size - 8/13/2007 2:59:04 PM
VFR_RC
Status: offline
i haven't cut it yet.
The top is the part that won't fit.
Where the windshield is bent to go around the black part that's formed like the wing's leading edge. The black part that has the wing's leading edge is about 16mm and the windshield is 15mm wide.
       Post #: 55
RE: New CMP Cessna 182 .52 size - 8/13/2007 3:05:18 PM
VFR_RC
Status: offline
windshield top width
Click for fullsize
       Post #: 56
RE: New CMP Cessna 182 .52 size - 8/13/2007 3:07:01 PM
VFR_RC
Status: offline
Fuse top leading edge width
Click for fullsize
       Post #: 57
RE: New CMP Cessna 182 .52 size - 8/13/2007 3:18:37 PM
damon
Status: offline
Is it possible to use the stock wheelpant with the Robart oleo strut on the nosegear. I doesn't look like it will fit.
Any suggestions?
       Post #: 58
RE: New CMP Cessna 182 .52 size - 8/13/2007 5:43:13 PM
opjose
Status: online
Could you post a pick of the windshield by itself so we can see the whole thing, including the white strip?
Thanks.
_____________________________
Build em'', fly em'', crash em'' and build more.
(in reply to damon)
       Post #: 59
RE: New CMP Cessna 182 .52 size - 8/13/2007 6:17:38 PM
VFR_RC
Status: offline
I'll take a picture of it when i get home. the only ones i can find with the while line are these:
Click for fullsize
       Post #: 60
RE: New CMP Cessna 182 .52 size - 8/13/2007 6:20:14 PM
VFR_RC
Status: offline
another view
Click for fullsize
       Post #: 61
RE: New CMP Cessna 182 .52 size - 8/13/2007 7:07:58 PM
Tracon
Status: offline
I had to trim mine a little on the outline as per the instructions, but it fits perfect...
You need to pull it back and put the bottom edge in the groove a head of the red trimon the nose and pull it over the two outside edged of the window frame...
       Post #: 62
RE: New CMP Cessna 182 .52 size - 8/13/2007 7:28:53 PM
VFR_RC
Status: offline
See if this explains it better. I know i can match the bottom part of the windshield against the groove behind the red lines but the problem is that the top won't fit OVER and AROUND the leading edge.
Click for fullsize
       Post #: 63
RE: New CMP Cessna 182 .52 size - 8/13/2007 9:20:07 PM
VFR_RC
Status: offline
Well i just talked to the Nitroplanes customer support. While on the phone, the CSR looked online at this thread and saw the problem. He's going to have a replacement windshield sent out to me.
These guys really do want to keep our business. My next plane will be the 140 size mustang and i am getting it from nitroplanes.
       Post #: 64
RE: New CMP Cessna 182 .52 size - 8/14/2007 12:04:11 AM
Tracon
