RE: New CMP Cessna 182 .52 size
Tower Hobbies
Logged in as Guest
Users viewing this topic: Caco
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: New CMP Cessna 182 .52 size
Page: <<   < prev  3 4 5 6 [7] 8 9 10 11 12   next >   >>
Login
RE: New CMP Cessna 182 .52 size - 6/30/2008 3:48:06 PM
Tracon
Status: offline
there's an off set for torque, I'd say about 1/8"
Sam
< Message edited by Tracon -- 6/30/2008 3:56:47 PM >
(in reply to damon)
       Post #: 151
RE: New CMP Cessna 182 .52 size - 7/1/2008 1:43:32 AM
turbojoe
Status: offline
My Cessna just got here. The low life UPS driver had the damaged side of the box turned away so I couldn't see it. By the time I got it inside and noticed the gaping hole he was long gone. My heart was sunk as I opened the box. That soon turned to elation as I noticed the damage was in a void area and nothing was destroyed!
As I pulled the parts out I wanted to kick myself for not ordering two or three. One for electric, one for glow and one for display. It's absolutely gorgeous! I have tons of other projects so I'll be taking my time on this one so it is just right when completed. I'm absolutely stunned with the appearance of this plane!
Click to see fullsize image.
Click for fullsize
_____________________________
Normal people scare the hell out of me!
(in reply to Tracon)
       Post #: 152
RE: New CMP Cessna 182 .52 size - 7/1/2008 6:50:49 PM
damon
Status: offline
Tracon,
Where did you run your antenna for your RX in the plane?
damon
(in reply to turbojoe)
       Post #: 153
RE: New CMP Cessna 182 .52 size - 7/2/2008 4:57:46 AM
Tracon
Status: offline
Inside the fuse..toward the tail...
(in reply to damon)
       Post #: 154
RE: New CMP Cessna 182 .52 size - 7/2/2008 3:29:05 PM
damon
Status: offline
tracon,
Did you exit the fuse with the antenna? If so, where?
damon
       Post #: 155
RE: New CMP Cessna 182 .52 size - 7/2/2008 4:33:39 PM
turbojoe
Status: offline
Tracon,
Did you weigh your plane before the motor and battery installation? I've weighed most of the kit as shipped and it's right around 4.5 pounds. Motor/esc/radio gear should add another 1.5 pounds. I'm not criticizing your power package, in fact I love to overpower everything too. It's just that for this plane I'm trying to keep costs down. I'm trying to put something together based on your 9.9 pound weight and for the cost involved it's just not going to happen. I need to keep the weight down so I can use some of the stuff that I already have. $250.00 for batteries, $200.00 for a charger for that battery, yet another motor and ESC.......Too much to spend on a $100.00 plane. I guess what I need to ask is this...Do you think it would have flown well on a lesser/lighter motor/battery combo than what you used?
Thanks!
Joe
(in reply to damon)
       Post #: 156
RE: New CMP Cessna 182 .52 size - 7/2/2008 4:56:26 PM
Tracon
Status: offline
quote:
ORIGINAL: damon
tracon,
damon
Nope....just coiled her up inside...
(in reply to damon)
       Post #: 157
RE: New CMP Cessna 182 .52 size - 7/2/2008 4:58:27 PM
Tracon
Status: offline
quote:
ORIGINAL: turbojoe
Tracon,
Thanks!
Joe
It might. but I know in tall grass I needed the power and the flaps to take off...
This isn't a cheap hobby and i really didn't know what to expect from this plane....it's just plain HEAVY !!!
       Post #: 158
RE: New CMP Cessna 182 .52 size - 7/2/2008 5:03:23 PM
damon
Status: offline
thanks.
       Post #: 159
RE: New CMP Cessna 182 .52 size - 7/6/2008 3:02:38 PM
geefish1
Status: offline
Tracon,
How do you install battery? Where you able to cut a hatch, or do you have to remove the wing each time you change battery? If you cut a hatch can I see a picture somewhere?
Geefish
       Post #: 160
RE: New CMP Cessna 182 .52 size - 7/6/2008 3:24:16 PM
geefish1
Status: offline
To anyone with the Cessna 182 52. size.
How do you put the battery in? There has to be a better way than taking the wing off everytime.
Any help appreciated.
(in reply to geefish1)
       Post #: 161
RE: New CMP Cessna 182 .52 size - 7/6/2008 9:56:03 PM
turbojoe
Status: offline
quote:
ORIGINAL: geefish1
This isn't my only plane so removing two bolts to pull the wing and the battery isn't a big deal for me. I'd rather do that than hack up this beautiful fuse to add a a hatch. I have seen a post either here or on RC Groups where the owner added a hatch on the bottom. I don't want to go to that extreme on mine.
Joe
       Post #: 162
RE: New CMP Cessna 182 .52 size - 7/7/2008 2:59:20 AM
geefish1
Status: offline
How about a cooling hatch? Did you cut one out at the bottom of the fuse. Also what power setup did you use.
geefish
       Post #: 163
RE: New CMP Cessna 182 .52 size - 7/7/2008 3:28:14 AM
turbojoe
Status: offline
Though I haven't done it yet I plan to add a few cooling air exit holes at the lower bottom of the fuse. Will also need to bore some holes in the firewall for battery cooling airflow. I'll wait until the motor gets here and I have mounting finalized before I cut those holes.
I got my Robart nose gear yesterday. What an incredible piece! I've been doing some work to the nose wheel pant to make it fit the Robart gear. I still have a bit of work to do on it. Monday I'll pick up the spacers I need to make it fit just right.
Joe
       Post #: 164
RE: New CMP Cessna 182 .52 size - 7/7/2008 4:28:56 AM
geefish1
Status: offline
Sounds Great. Im going to put an e flite power 46 brushless motor and 4s 4270mah batteries. What about you?
       Post #: 165
RE: New CMP Cessna 182 .52 size - 7/7/2008 4:59:55 AM
turbojoe
Status: offline
quote:
ORIGINAL: geefish1
Scorpion 4020-12 motor with 13x6.5 prop and 6S 4000 Li-Po to start off with. Should be close to 1KW power. I'm sure that'll get her off the ground.
Joe
       Post #: 166
RE: New CMP Cessna 182 .52 size - 7/7/2008 5:57:14 PM
Tracon
