zener3
Joined: 9/5/2008 From: Sugar Land, TX, USA Status: offline
quote:
ORIGINAL: zener3 OK, well, apparently I screwed up somewhere. I took the plane to the field today and got it ready. Double checked all my throws and controls. Engine ran perfectly. did the range check, all ok. Started my takeoff roll, no flaps, started to rotate and the plane pitched to the left and made a really low left hand curve to the fence and crashed... I tried to aileron it back right when it happened but it didn't seem to have any effect on the bank. Crosswind of about 5 - 8 mph Post mordem - , all control surfaces still worked and all operated in the proper direction and throw. CG of the plane was at ~68 mm and was double checked at the field. Several of us at the field speculated that I must not have had enough airspeed when I attempted to take off in the crosswind. This plane has relatively small airfoils compared to the trainers I am used to flying. *****************8 The story doesn't end there! ************************ I put this wreck away, and got my sig Kadet Sr. out so that I could enjoy part of the morning anyway. This plane is 72 mhz and I usually have to share the 46 pin with another pilot at the field. He and I joke with one another and we enjoy watching each others planes. Anyway, I got the pin from him and fueled my sig, got her in the air and was flying for about 5 minutes when it suddenly started acting bad. I had control , then not, up, down, everywhere. Well, I don't need to explain what happened. The other fellow got his battery changed and brought his plane back out to the flightline. We both brought the pieces of both wrecked planes back to the bench, packed up, and went home... He is having the new plane delivered to my house. I'll order another 182 ARF and salvage the parts from this one. Any help, comments, suggestions would be welcome before I attempt to fly it again. Thanks Last night I stripped the C-182 plane to get ready for the new one to arrive. The fuel tank stopper had come out when the plane crashed. I noticed that whoever built this plane didn't use regular fuel line on the clunk line. Instead it looks like ordinary plastic line and had a split in it for the first cm or two on the stopper end. I wonder if the plane lost power on takeoff. I tested it with full power before flying but the G-force can only be tested on the runway. I was concentrating on righting the plane and really didn't notice what the engine was doing just before the crash.
