FUJI43EI : Idle is not stable
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Fuji-Imvac Engines Support >> FUJI43EI : Idle is not stable
Page: [1]
Login
FUJI43EI : Idle is not stable - 7/4/2007 1:58:57 AM
Prapan
Status: offline
Would you please help me how to resolve the unstable problem of idle....I installed FUJI43EI on EDGE 540T wingspan 85", This engine passed break in already since I fly more than 20 times. (12 mins each time).
However since the beginning when I purchased this engine from Towerhobbies. I still cannot get a very stable idle speed so far.
I used KLOTZ oil with 32:1 and 95 octane.
Prop APC 20 x 8 and get max speed at 7300 rpm.
I tune the engine by starting from the instruction manual (3/4 turns from close position for HIGH and 1-3/4 turns from close position for LOW)
The transition from zero to mid range is OK and transition quickly from zero to 100% is a bit slow but the engine is not stop.
When I move throttle stick down to zero and wait for idle a bit about 1 mins then I listen the idel speed and sometime is overspeed and sometime is slower for a while So I have to move forward throttle stick to keep motor running.
Sometime if I wait for 3-5 mins I observe the idle speed is slower and stop sometimes. It is not like other Gas that I have such as DA, 3W, ZDZ...
I used 4.8 volts 1500 mAh FUTABA battery pack for EIS and connect ground wire of EIS to engine mount.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Prapan
       Post #: 1
RE: FUJI43EI : Idle is not stable - 7/5/2007 6:01:45 PM
Bax
Status: offline
Open both needles to 1-1/2 turns out from closed and then adjust them from there. Start by adjusting the high-speed needle first. It sounds like your engine is too lean on the high-speed needle, which will affect the low-speed running.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to Prapan)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU5
