RE: F27 STRYKER -Way Past the Limits Part 6 -Go deeper in to the Dark Side...
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
F-27 Stryker
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> Electric Aircraft Universe >> Park Flyers & Backyard Flyers >> RE: F27 STRYKER -Way Past the Limits Part 6 -Go deeper in to the Dark Side...
    Page: <<   < prev  95 96 97 98 99 100 101 102 103 [104]
    Login
    RE: F27 STRYKER -... - 5/6/2008 6:18:45 AM
    iamman711
    Status: offline
    thanks Stryker_Viking for the visual aid. appreciate it as usual.
    thanks Gryphon for part 6. i saw pictures of reaperofsoulz's motor mount up close at this thread by the way.
    (in reply to Gryphon)
           Post #: 2576
    RE: F27 STRYKER -... - 5/6/2008 4:46:09 PM
    Gryphon
    Status: offline
    Sirpa,
    I hope you solved your problem,
    Read post #2545 on page 102.
    In general it is recommended to have 2 identical servos.
    In that post, read #2 and that might help you.
    Edit: in your case, you may need the travel adjusts to be different, at least 2 of 4 numbers????? Play around with it, and check the basics.
    Good luck,
    Gryphon
    < Message edited by Gryphon -- 5/6/2008 4:49:06 PM >
    (in reply to iamman711)
           Post #: 2577
    RE: F27 STRYKER -... - 5/6/2008 11:56:55 PM
    Gryphon
    Status: offline
    Guys part 7 has been started:
    http://www.rcuniverse.com/forum/m_7464076/anchors_7464083/mpage_1/key_/anchor/tm.htm#7464083
    Gryphon
           Post #: 2578
    RE: F27 STRYKER -... - 5/7/2008 12:39:35 AM
    Gryphon
    Status: offline
    I want to take this opportunity to thank everyone.
    Special thanks to the thread starters of part 1-5: lotrusty, Glacier Girl, gogofast, critterhunter, somegeek.
    Thanks to your hard word and contributions the F-27 has been transformed into many shapes and with various performance levels for various applications. Countless people have been helped by you.
    I have to give thanks to DepronJet (AKA cadetman) for his contributions.
    ***** I want to thank all the people who posted on part 1 through part 6.
    With mutual co-operation we all learned from each other.
    I truly enjoyed starting part 6 and working with many of you though the various threads.
    On a final note: Buggygovroom, your 120 MPH Stryker video is my favorite high speed Stryker video of all time, but I have a feeling Part 7 will produce some videos to seriously rival it.
    http://www.youtube.com/watch?v=OKaRnhg3JkQ&feature=related
    ************* Hint: Last comment was a challenge to everyone. [)]
    Let’s keep it all going in part 7 with help from chippedprop:
    Thanks again everyone,
    Gryphon
           Post #: 2579
    RE: F27 STRYKER -... - 5/7/2008 12:41:49 AM
    JDXX
    Status: offline
    Been a while since I have checked in here, a lot of pages have gone by. I will eventually read them and see what has been up in the Stryker world. I just want to thank Gryphon for this thread. Gryph You have been very helpfull to many here, you are a Stryker God now.
    I have flown mine a few times lately and will tell my stories soon.
    Thanks again Gryph your help and through info brought me into this and I am not nearly finished.
    JDXX
    StryXXr...........................Coming soon
    Three cheers for Grypon..........HIP HIP HORRAY HIP HIP HORRAY HIP HIP HORRAY
    < Message edited by JDXX -- 5/7/2008 2:28:41 AM >
           Post #: 2580
    RE: F27 STRYKER -... - 5/7/2008 1:21:31 AM
    Stryker_Viking
    Status: offline
    ~~~~ A BIG THANK YOU FOR ALL YOUR HELP HERE GRYPHON ~~~~
    Stryker_Viking
    _____________________________
    - - - Altitude is still my best friend...
    (in reply to JDXX)
           Post #: 2581
    RE: F27 STRYKER -... - 5/7/2008 2:29:17 AM
    Gryphon
    Status: offline
    Thanks for the kind word guys,
    I need to do something as far as making a partial Index of some sort.
    I hope to lock this thread down by tomorrow, 100+ pages to go through...WOW
    See you in part 7.
    Gryphon
    < Message edited by Gryphon -- 5/8/2008 9:41:41 PM >
    (in reply to Stryker_Viking)
           Post #: 2582
    RE: F27 STRYKER -... - 5/7/2008 4:27:50 AM
    sirpa
    Status: offline
    quote:
    ORIGINAL: Gryphon
    Sirpa,
    Good luck,
    Gryphon
    I found finally a solution to that problem . I had used too much right trim on the transmitter and the control horn on the right servo was moving less up that down .Actually , I don't understand why it was moving all the way up while pulling the stick but not when turning right ? Anyway, it's working fine now , thanks , and I am waiting to give it a try . I just happened to loose the usual place where I was flying because of some new houses starting to be build right there . I now have to drive 45 km to find a correct place to fly that bird. That will limit a lot my flytime !! too bad.
    fortunately , I have also a superfly that can be flown in my backyard . It just isn't that fast but is more fun anyway .
           Post #: 2583
    RE: F27 STRYKER -Way Past ... - 5/14/2008 1:54:25 PM
    R-22
    Status: offline
    quote:
    ORIGINAL: little dirty
    Nice Viking!
    I have already built one also but have not been able to find the bungie. I now found one on the internet for like 50 bucks( its 40 ft long ).
    What do you think i should use? How much does the surgial tubing cost ? and is it as stretchy as bungie cord?
    Hi dirty
    I bought two 10' lengths of latex surgical tubing at home depot in the plumbing section. Kind of expensive at 18 dollars per length. Only 2 required for a stryker. Just tie them together with just a square knot. It won't come loose. I use a corkscrew dog tie down at one end, no worries about that coming out.
    My launcher is just made of wood, not too long, fits in the trunk of a Camry easlily.
    I just tried it yesterday, I very new at this and still nervous, but this launcher has made it easy. Launched 10 times, perfect every time.
    It's actually fun just launching. Hit the pedal and 1/2 second later your stryker is 100' away floating about 10' high waiting for you to hit the throttle.
    You don't even need much tension and you can launch with a breeze behind you no problem. I believe the surgical tubing is far better, stretches farther so less strain on everything. However it might rot over time. I'm also wondering if it is better to undo the knots for storage. I've heard store in a dark place(certainly not in the sun!) in a container with talcum powder.
    R-22
    (in reply to little dirty)
           Post #: 2584
    RE: F27 STRYKER -Way Past ... - 5/15/2008 3:16:32 AM
    dunk
    Status: offline
    Here are some newbe questions....
    With the factory motor ans esc and the factory lipo, is there anything to get more speed ...I though a larger lipo like 2200 20c.
    Also I have a align 23amp esc and an align 430L 3550kv motor that is not being used. I was wondering if any combo of these two esc's and motors would get a little more speed.
    I have a 3s1p 2200 mah 20 c pack and a 3s1p 3300mah 20 c pack and a 2200 4s1p 20c that I have not tried at all. I am ordering a watt meter to help me not burn something up. Also what prop size would work..
    Forgot that I also have a suppo outrunner 2814-06 and 40amp esc with a 2200 lipo that makes a mini ultra stick hum...
    Any info would be greatly appreaciated....the stryker is yearning for more speed!
    Dunk
    < Message edited by dunk -- 5/15/2008 3:27:35 AM >
    (in reply to R-22)
           Post #: 2585
    RE: F27 STRYKER -Way Past ... - 5/15/2008 5:17:44 AM
    Gryphon
    Status: offline
    Hi all,
    We are finished with this thread and I'm slowly working on some sort of index. That is why it has not been locked down yet.
    Don’t worry Part 7 has been started.
    PLEASE PLACE YOUR FUTURE POSTS ON THE PART 7 THREAD.
    For your convenience I am including a link to the F-27 Part 7 thread below.
    http://www.rcuniverse.com/forum/m_7464076/tm.htm
    Thank you.
    Gryphon
    (in reply to dunk)
           Post #: 2586
    RE: F27 STRYKER ... - 7/9/2008 11:45:43 PM
    fossoman
    Status: offline
    Ive got the F27C Stryker anyone know of a faster motor without changing out the stock ESC? A motor that will mount up the same with the right shaft diameter. Love my stryker but the motor is a little beat from a few crashes and I thought why buy a stock brushless if I can find something better.
    Always Remember no matter where you go, There ya are
           Post #: 2587
    RE: F27 STRYKER ... - 7/10/2008 2:45:02 AM
    Gryphon
    Status: offline
    fossoman,
    Read the post above yours.
    (in reply to fossoman)
           Post #: 2588
    RE: F27 STRYKER -Way Past the Limits Part 6 -Go deeper... - 8/24/2008 11:46:37 PM
    flyingplumber68
    Status: offline
    need to know if an e flite 40 amp v2 esc and an e flite 2700 kv six series brushless motor with an apc 7x6 sport prop would help push my stryker a little faster , getting bored with the speed it has now. I need more speed , man! any insight into the matter would be most appreciated .
    (in reply to tam popo)
           Post #: 2589
    RE: F27 STRYKER ... - 8/25/2008 2:14:50 AM
    Mr. Mugen
    Status: online
    http://www.rcuniverse.com/forum/m_7464076/mpage_46/tm.htm
    Ask here.
    < Message edited by Mr. Mugen -- 8/25/2008 2:15:09 AM >
    Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
    (in reply to flyingplumber68)
