Gryphon
NC, USA Status: offline
Stryker_Viking, MEDUSA RESEARCH Comments: Where do I start my friend: My comments are going to hurt a little, but it’ll be good for you. I wouldn’t do it if you were not my friend. If it was one of the other guys, I might have tried to be more tactful. So you drew first blood on MEGA, and if you were right, then I wouldn’t have said anything. Here go the real facts followed by real analyzing of your own chart: Your bigger and heavier Model MR-028-056-2800 is inferior to my MEGA 16/25/2 2650KV. Sorry, it is true. Some of the supporting facts are showed by your chart up there, some of it is not and I will include them. So listen up please. First some of the reason for my tone is because I never posted MEDUSA Killer and you have done this (MEGA killer) repeatedly starting with the part5 thread. So hopefully it’ll be cleared up once and for all. No I don’t take it personally, but I’ve had to respond to your inaccurate posts more than once. My tests were done with a battery that you bought from me. Remember the TP 4S-3300 22C that you said you wanted after I cycled it and personally flew with it less than 8-10 times. So with that smaller battery that I logged my test with compared to the battery you used to do your testing, here is what I see: You lost so much efficiency trying to run Graupner CAM 5.5X5.5(same as me) that you drew 250W more(nearly 25%) while spinning LESS RPM………At least you mentioned that in your post, but not in so many words. NEXT you show that when I ran the Graupner CAM 6X6 prop, I made 1206W with pitch speed of 161MPH at 28290RPM. So now let’s compare that to your 5.5X5.5. It shows that while you drew 1/8 more power out of your battery (150W) you had 11MPH less pitch speed. I’m not even sure it is worth mentioning yet that the thrust difference is huge, that will come late on. BUT wait a minute, How come you didn’t post my other 6X6 test run, the one I posted many times and also gave you the information. Let me refresh your memory. With CC80A ESC on high timing advance which is less efficient, I drew 1330W and 28800RPM with 164MPH pitch speed. So now, lets compare that to your 5.5X5.5 run. Well it looks like while I was spinning a larger prop with more pitch I was still more efficient than you, because with the same power in 1340W +/- 10W, I had 14MPH more pitch speed. I’m not even sure that I should talk about the thrust difference yet. I’ll save that for a little later on, but soon. Let’s go to your run on APC 5X5 1221W and 166MPH pitch speed. Compare that to my 6X6 run that you posted; 1206W 161 MPH pitch speed. I will ask you this: DOES OUR PLANES FLY AT 160+MPH ACTUAL SPEED OR MORE LIKE ABOUT THE 125+ TO 130MPH RANGE ON 4S ?????? Now that you agree we fly closer to 130MPH, does it make a difference between 161MPH and 166MPH Given the same power input to the motors? Didn’t think so. It’s about time to talk about the thrust: ***** 5” prop Vs 6” prop at about the same pitch speed and power intake. What do you think is the thrust difference? My friend, take note, THAT IS A HUGE DIFFERENCE. To some one that I didn’t like I would say to actually tattoo it somewhere…. You I love like a brother and a great friend. But I’m not done yet with this post, there is more. I will make sure to never hear MEGA killer unless it is factual. So there is more clarification needed for you. So now you can see that the higher efficiency that you are looking for compared to the MEGA has not happened at 5” prop for you. So let’s go look at your 4.75” prop. You got your best efficiency at 4.75” prop, do you think that is the best prop for you at 130MPH? Do you think that prop will reach 130MPH in a Stryker? If the Stryker was a thin wing, a good deal thinner and had less drag like a Funjet or something, then your motor MIGHT have an advantage. But I wouldn’t even give you that unless Radar runs prove it. Not finished yet. So lets talk about 5S…….What prop will you run then? 4.1” prop? Do you think at 140 MPH when the drag is going to be roughly twice that of 100MPH that the 4.1” prop is going to be ideal, or even enough? It is not all about pitch speed, if you don’t have the thrust you will never reach the higher speed. It will be like doing a huge burnout at the drag strip, you can spin your wheels and go nowhere. Lastly, I think you will hate me for this one, but I owe you this one: Are we talking about the same motor that you burned out and had to send in for repair??? It is not really a question because I saw it. This brings me to the next point. MEGA motors run very COOL, more cool than Medusa motors. What the pics of the Medusa Motor does not show is that it is fully sealed. It is lacking the 4 very large holes in the front and lacking another 4 large holes in the rear. Now I know I was a little sleepy with the blanket over my head at 1:30 a.m. but did you ask me (over the phone) if I thought that 100-140MPH air going through the inside of the motor made any difference in cooling it? Well I know I was not dreaming and YES, IT DOES MAKE A BIG DIFFERENCE. That would be a disadvantage to a MEGA motor if someone wants to land and operate it in dirt and dust. That is why medusa and also some of the Military specified motors are fully sealed. That is a plus as long as they don’t get fried. Since I don’t have data on your motor and 3S, I will say, like before , that your Medusa motor which is 50%heavier than MEGA 16/25/2 2650KV when on 3S will have a slight advantage (just to be nice like I’ve been). I am pulling that out of the air. Just because you over propped your motor on 3S once to get a big number does not make it right, or more powerful though. But on 5S your Medusa has a disadvantage partly because of its KV being too high. On 4S I knew I had the better motor but didn’t want to say it, because they were close enough. I was just very happy that because of hanging out with me, you tripled to quadrupled the power of your Stryker. The difference was close enough that I didn’t want to put your motor down. I think that extra and super long 480 sized 2800KV Medusa it is a great motor, no it is a fantastic motor, honest. Recall how you picked that motor? My other friend said something to you a few times and you wanted to outdo him, not necessarily outdo me and you didn’t want to get the same motor. I made sure you knew to at least go for a low resistance motor which you did. Great choice, but not only it is not a MEGA killer, but it is extremely close to being almost as good as the MEGA 16/25/2. Just now, I read over your post again and saw the time of your post. I also just remember that last night I asked you to not post anything like that for a personal reason that I gave you. I said to give me 2 weeks. So I see that you just put up another post with “it seems this and that” comments. Let stick to the tested facts my brother. I kind of wish I stated a few more things, but those may have to be in future if this MEGA killer stuff continues. I guess more detailed testing will be needed. Take Paul with you when you are ready for more radar runs. Let’s compare some real numbers and see. Actually I just did that and none of it was theory but your own actual testing. Problem lies in your bad analyzing practices of the above data. Lets agree to get off of this subject till we have verified some radar runs starting from now. I will try to bust 120MPH on 3S. Will your motor hang with that? ****AS A REMINDER MEGA WINS USING A SMALLER BATTERY WITH LOWER "C" RATING. Imagine if I had ran a bigger battery. I have the same battery as yours and I will solder and start cycling it this weekend. Remember same battery as yours that we bought at the same time and we split the bill? PUT THAT IN YOUR PIPE. I expected you to listen to my request last night. I would have listened to yours. Gryphon
< Message edited by Gryphon -- 7/12/2007 1:13:37 AM >
