Gryphon
NC, USA Status: offline
iamman711 WELCOME to the DARK side. You have great vision. I’m impressed. Everything that you want can be fitted to the Stryker. Without passing any limits because there are none. Take a fuse (old/broken one at first if you have one). Lay the parts that you want in their general area. Place Retracts, servos in their general area. Make sure your parts are not thicker than that area of wing. Place ESC and receiver in wing as needed. See my receiver on top of wing at the bottom of page 75(mine is a belly-lander). BubbleGum has landing gear and he has his receiver under the wing near the front (to avoid interference in his high powered setup). But either way we freed up real estate under the hatch. Ask him for links to his page or search this thread using his name. With ESC and receiver out of the way, and maybe retract servos close to retracts, the situation of fittings things don’t look so bad huh. Make sure to extend the 3 ESC to motor wires instead of the 2 ESC to battery wires if/when needed. If you want a full size cam to be removable, consider mounting it on the center of gravity, so when you put it in and out it will not throw your C.G. off. You can install a full size cam and you are that much better off with FlyCamOne V2. I suggest you contact AeroRecon since he might have given this more thought already. Since your cam is not so heavy: If it is to stay in place, then C.G. close to stock points. If it needs to be removed, then C.G. on stock location without it if it is mounted in front. If it needs to be removed and it gets installed in rear, then setup so with cam installed it is on stock C.G. location and nose heavy with it removed. Goal is to never be tail heavy. Lay C.F. tubes, and strips to strengthen the areas that you weakened. 3M Extreme tape can help. Then carve away foam for parts and also for C.F. Add wood/fiberglass/hot glue or whatever as needed to bolt your retracts to. Use servo tape under servos (double sided tape). I have not installed retracts so ask others and do research if you have not done it before. Don’t not sound so impossible anymore…huh? When there is a will, there is a way. I’ve only seen retracts once a couple of years ago and don’t know where to refer you to. If it is not a 100+ MPH Stryker then shoot for stock C.G. points. Initially tape everything in their general location, then nudge various parts around a little to help you. Up to 1” forward C.G. is o.k. In your case, weight is no longer an issue because you will roll till you get enough air speed, If you want us to find you a little more power, list your main components, and other parts that you have which may be useful. _________________ Do a hand sketch of where your parts might go and post it. Gryphon.
< Message edited by Gryphon -- 3/25/2008 7:24:21 AM >
