DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: online
quote:
ORIGINAL: CustomPC At the end of the day I was getting peaks of between 10,800 and 11,000 RPM with a Bolly 12.5x6 Clubman prop. CPC, None of us have had any doubts about Ken Enya's engineering talent... This RPM on this prop represents 1.25 HP, which is a whisker less than the MAN/Gierke 05/03 shootout average, BUT this is at 2,000 RPM less than the same and it seems allowing this engine to rev by propping it smaller, may allow it to exhibit higher HP numbers than Dave Gierke saw... Would you mind telling us what this engine can achieve with other prop sizes - 11x7.5, 11.5x7, 11x7, 10x8, 10.5x8, 13x6, 13.5x6...? I believe it can already be peaked to full power, with absolutely no risk. From these numbers it would be possible to plot the HP curve and to ideally prop it for best performance.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
