a088008
Joined: 6/14/2002 From: San Diego, CA, USA Status: offline
Thanks for the very interesting post. I'm intending using about 5 degrees or less reflex on the ailerons. Another nice thing about reflex is that I get less down-travel on the ailerons which further reduces the changes of tip stall. -Q. [QUOTE]Originally posted by Johng Yes, aileron reflex intruduces washout to the wing - but so do flaps. Using either or both reduce effective angle of attack on the outer wing. Now, during takeoff, the wing alpha can be very dynamic and the reflex can help alot. Gliders routinely use "crow" for landing, which includes flaps deployed downwards and ailerons reflexed upwards. The main purpose of this is to add drag. However, it also makes the long wing almost unstallable. I have sunk-in my glider at a 45 deg angle with the fuse level. The other consideration is that reflexing ailerons causes pitch-up force, noticable even on a conventional layout. Same thing goes for funfly planes, but they usually call it "airbrake". You can get a plane going real slow with that setting engaged. I used it an a giant stinger. That thing could creep along. Drag the tailwheel on landing too. I have used a "crow" setting specifically for takeoff one one of my planes. It's a 4m sailplane with a self-launch pylon motor that weighs 10 lbs. The tip chord is about 3 inches. I launch it from a dolly cart, using a bungee-assist launch hooked under the nose. So, there's all kind of wacky stuff going on at once. You pull back this plane on a slingshot, sitting on a cart, with an offset-high thrust line. It takes full up elevator to get the thing up off the cart clean. Then I let off the elevator off as it picks up speed and the bungee drops away. For takeoff I have the flaps set down about 20 degrees and the ailerons are up between 5 and 10 degrees. I have never had a wobble or hesitation in 15 or 20 flights. Would it work as well without the reflex? I have no idea, since I'm not going to bet this big plane on trying it without. It works, I ain't changing I can't get any more flap travel for landing( strange - it came hinged like that) , so I use the same settings for landing, but I also have spoiler available for glide control. Anyway, from what I've read, I understand that this is essentially a flying wing, which means pitch control is thru the trailing edge devices. Which means that setting the ailerons "up" will also increase the pitch up forces. That could be ugly on a frst flight all on it's own. This will have to be balanced with deflection of flaps downward. If there is any sweep in the wings, the ailerons will have more pitch authority than the flaps. If you want to use reflex, not more than 10 degrees should be fine. [/QUOTE]
_____________________________
-Q
