M.R. Ogle
Joined: 4/18/2005 From: Mount Vernon, IL, IL, USA Status: offline
Here's what I've done in research for gearing on the 23CC drag cars: I think I'm getting there, figuring out the correct final drive ratio for my car. It has two primary gears, then pulleys from the halfshaft to the rear axle. 15/48 gears 16/72 pulleys..... (14.4:1) way too low, car spun it's tires hard but topped out at 65 feet. 15/48 gears 21/48 pulleys... (7.31:1) too high, stripped rear belt (at Minnesota). 21/40 gears 16/72 pulleys... (8.55:1) Better, ran at Chicago like this (best of 3.15 ET). 20/44 gears 16/72 pulleys... (9.9:1) Will try this ratio next time out 20/44 gears 14/72 pulleys...(11.3::1) May also try this combo. May be good on a treated track where the tires stay hooked up, and will work the clutch real hard. This is what I've tried so far. I'm surprised that the sweet spot is so narrow on these motors, but they're pulling 25 pound cars through a centrifugal clutch, so you gotta pay close attention to what the car's telling you. Of course, with a two-speed, you'll have more options, and you can gear low to come off the line hard, then shift up as to not run out of steam halfway down track. My car ran 3.15, which was pretty good, but Guy Hilleary was way under three seconds with his, best of 2.78, I believe.
_____________________________
Mike Grand Motorsports.com
