gboulton
TN, USA Status: offline
Zippi, You don't say if this is one of Ralph's G62's or not...if it is, here's another thing to check. There's a small (maybe 2" long if that) black neoprene hose from the crankcase to the carb, providing pulse pressure. That neoprene tends, for some reason, to dry-rot and crack fairly quickly...as it starts to go, it can cause no end of oddball problems, including shutting down the engine, backfires, surging, you name it. Check it, and if it's the least bit suspect, replace that with a piece of Tygon (or some other gas line of your choice). (Personally, I just replace it right away out of habit now, without even looking at it) Don't know that that's it, but since learning of that issue with one of mine (thanks nogyro), I've seen/heard about it on quite a few 62's, and it's caused a rather wide range of seemingly unrelated problems. HTH
_____________________________
The free man will ask neither what his country can do for him nor what he can do for his country. - Milton Friedman
