STEVE MARSHALL
Joined: 1/25/2007 From: Perth, AUSTRALIA Status: offline
Well had it out again today, Not alot of joy. But did manage to get another 1.5kmh out of it, its now doing 45.4kph. It's still only getting half the revs it's got. I started from scratch, 1 1/2 on both needles, then up and up on the low one to get good off the mark and mid range. Got to a point on the L and things went backwards, so back to the last setting on the L. then started going up on the H, at times it would have just a flat spot and others it would serge but never rev out. (idle was all over the shop as well) I found a happy spot and then played with the strut, up,down,trim up, trim down. The only thing I didn't try is cranking the tabs down to lift it's but out of the water. I think now I will remove the carb and isolator block and check the gaskets and surfaces, The H does'nt seem to be doing much at all. I know its got more,(Hope alot more) its a matter of finding it. Steve OH Yea, just about rolled it too, it doug in on a corner, a bit fast and turning too sharp, it just glided along on it's side for about 3 boat lengths and then flopped back down and stalled lol, even my son said oh sh#*## as I did.
