RE: 54in Mono Build
Tower Hobbies
Logged in as Guest
  Printable Version
U-95 HYDRO - Kit
Seller:  rjhobbycraft
Details:   $349.95   |  11/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: 54in Mono Build
Page: <<   < prev  10 11 12 13 14 15 16 17 [18] 19   next >   >>
Login
RE: 54in Mono Build - 2/5/2008 10:02:09 AM
martno1fan
Status: offline
smaller prop will wake it up but try raising the drive so less prop in the water and see what happens .
_____________________________
im not argumentative im just missunderstood
(in reply to STEVE MARSHALL)
       Post #: 426
RE: 54in Mono Build - 2/5/2008 8:33:54 PM
bentley marshall
Status: offline
sounds like its under to much load try lifting the prop out ot the water get about 3-4 deg up and yeah try a 270-275 prop
(in reply to martno1fan)
       Post #: 427
RE: 54in Mono Build - 2/5/2008 9:53:51 PM
martno1fan
Status: offline
he could also do a back cut on the 280 and that will wake it up a bit maybe.
(in reply to bentley marshall)
       Post #: 428
RE: 54in Mono Build - 2/16/2008 1:10:03 PM
STEVE MARSHALL
Status: offline
Hi all, Its been a while, but while i was away a X470 and a WT257 arrived in the mail. No testing this time home, but i will get to sharpen and balance the prop for next time. I also have to do a bit of repair work on the nose when i hit the limestone wall (don't want water getting into the ply) First I will try the X470 with the old carb, I am sure it will wake up with a smaller and lower pitch prop. It's the young blokes 8th birthday this weekend so can't play with the boat much. Will keep you informed.
Steve
       Post #: 429
RE: 54in Mono Build - 2/16/2008 2:20:23 PM
martno1fan
Status: offline
Hi mate what carb does it have at the moment? you wont see any diff between the 644 and the 257 in my opinion.Tha x470 will def wake the motor up im sure,as for the carb depends what carb you have on it now,but from what ive been told the 644 and 257 carbs are basicly very similar apart from the 644 has a choke.
       Post #: 430
RE: 54in Mono Build - 2/16/2008 2:59:22 PM
Macleod
Status: offline
The reason Steve got the 257 is because the current carby (a 644 copy with mods) he got with the clone zen, doesnt seem to be running right. Better value buying the 257 than replacing the 644 copy with a true 644.
The 257 has no primer or choke and doesnt need the spit tube either.
Ross
Decerto Racing....There can be only one....
       Post #: 431
RE: 54in Mono Build - 2/16/2008 3:20:25 PM
martno1fan
Status: offline
If its not running right then he might as well change it now before he runs it? ,my worry is its not the carb thats the problem but the motor itself.hope not but it is a copy not a true zen,hopefully he can get it running but ive not seen or heard of anyone running this motor before have you?.
(in reply to Macleod)
       Post #: 432
RE: 54in Mono Build - 2/16/2008 11:56:02 PM
STEVE MARSHALL
Status: offline
I will try the prop(X470) with the coppy(modded) carb(644) first. If it wakes up the motor, i will then put on the 257, and see if there is any differance. It's no good doing both at once because you wont know what fixed it, prop or carb.
Steve
       Post #: 433
RE: 54in Mono Build - 2/17/2008 12:41:37 PM
martno1fan
Status: offline
i agree but yer mate said the carb wasnt working so i asumed it was busted lol
       Post #: 434
RE: 54in Mono Build - 3/1/2008 11:30:03 AM
STEVE MARSHALL
Status: offline
Hi all, it's been a while, the X470 is all balanced up, the dings in the paint have been all touched up, all i have to do is charge the batts and see how it goes, will have a update in the next day or 2.
Steve
       Post #: 435
RE: 54in Mono Build - 3/1/2008 12:00:56 PM
martno1fan
Status: offline
Sounds good Steve good luck with it mate,you should be proud of the build she looks great now lets hope she runs as good as she looks .
       Post #: 436
RE: 54in Mono Build - 3/3/2008 10:15:06 PM
STEVE MARSHALL
Status: offline
Hey where did the last few posts go.
       Post #: 437
RE: 54in Mono Build - 3/3/2008 10:25:05 PM
martno1fan
Status: offline
the site went down for a while ,what a pain in the ass ive had a few posts removed too
       Post #: 438
RE: 54in Mono Build - 3/3/2008 10:46:14 PM
s2sinner
Status: offline
quote:
ORIGINAL: STEVE MARSHALL
Steve
Hello Steve.
Well i have ready my 72 but we have a storm in Switzerland and I will make the test tomorrow if the weather is better....Have you try the 470 yet?
Let me know please Thanks..
Vassilis Greece ( Living in Switzerland)
       Post #: 439
RE: 54in Mono Build - 3/3/2008 10:57:38 PM
STEVE MARSHALL
Status: offline
here is a link to the run yesterday, still no top end and it had the 470 on it. the 644 is off and the WT257 is getting a try.
http://www.youtube.com/watch?v=bef5je8BzyQ
(in reply to s2sinner)
       Post #: 440
RE: 54in Mono Build - 3/4/2008 7:52:18 AM
s2sinner
Status: offline
Thanks Steve.
Well today looks at the moment good day ( gold but not wind today ) I will put it in the water and give a try I will recorded for all of you.
I will try the 470 ( after all I have 51.7cc ) and we will see.
Thanks for the video.
Vassilis
       Post #: 441
RE: 54in Mono Build - 3/4/2008 8:19:58 AM
STEVE MARSHALL
Status: offline
Well I had it out again today, and boy that motor can rev now with the WT257 on it. 59.2kph at about 2/3 throttle, the big problem now is to try and stop it from trying to do a barrel roll. I also smacked head first into one of the markers in the pond (the yaught guyes put them out) you should have seen the poly fly lol. but it did a fair bit of damage to the boat, cracked the hull on the RHS(pic) a
