RE: 54in Mono Build
Tower Hobbies
Logged in as Guest
  Printable Version
U-95 HYDRO - Kit
Seller:  rjhobbycraft
Details:   $349.95   |  11/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: 54in Mono Build
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: 54in Mono Build - 7/10/2007 7:44:11 AM
martno1fan
Status: offline
nice flowers at the end terrible song ,boat seemed to go not bad at all but too many fade ins and outs makes it hard to tell which was with and without the double rudders.im sat here with 2 1/2 hrs to go till the taxi comes to take us the the airport for our hols maybe when i get back you will have got a better carb for your weedy!!.who knows you might get your bigger boat finnished by then .
_____________________________
im not argumentative im just missunderstood
(in reply to STEVE MARSHALL)
       Post #: 26
RE: 54in Mono Build - 7/10/2007 12:38:05 PM
STEVE MARSHALL
Status: offline
I got to fly back to work in the morning so i will up date in 10 days time. When i get back i should have a pile of goodies here. Clutch and waterpump from o'neil bros, engine mount,7016propshop prop,trim tabs,auto bailer and a collet from rc jets. will post pics when i get back. see ya
< Message edited by STEVE MARSHALL -- 7/10/2007 12:56:00 PM >
(in reply to martno1fan)
       Post #: 27
RE: 54in Mono Build - 7/20/2007 1:40:13 AM
STEVE MARSHALL
Status: offline
Hi all, got back from work last night, and home for 19 days this time. All my goodies arrived. will get into the boat later today.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 28
RE: 54in Mono Build - 7/20/2007 1:17:44 PM
STEVE MARSHALL
Status: offline
Ok got into it again today, got all the frames sanded and the jig set up then glued it together.Everything is square and in line. Also is a pic of the woodie my son took. I also orderd a motor today, I ended up getting the BM260 STAGE 2 MOD Clone from RC JETS. It should arive friday. (Mart will have something to say about that)
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by STEVE MARSHALL -- 7/20/2007 1:45:55 PM >
       Post #: 29
RE: 54in Mono Build - 7/21/2007 10:23:19 PM
bentley marshall
Status: offline
whats the go with the flag bro your a KIWI!!!! boats looking good should be finished befor ya go back to work
       Post #: 30
RE: 54in Mono Build - 7/23/2007 5:07:32 PM
Xirus
Status: offline
I'm in the same boat as you with the length and all. ha ha.
Anyway. I will probably be the first to put the full 72" in the water if I don't end up cutting it down. I have everything cut and will be gluing it tonight. I'll try to get some pictures up as well.
(in reply to bentley marshall)
       Post #: 31
RE: 54in Mono Build - 7/24/2007 11:22:05 AM
STEVE MARSHALL
Status: offline
Hi all, Xirus, I got my plans printed at 75% at the printers and then added 25mm to the centre of the V to make the boat wider. So mine will be 54in long and 12in wide (at the widest point) I will see how it goes. Come on show some pics of yours. Here are some update pics, I started the hull sheeting all glued and nailed, tomorrow i will pull the nose down and glue it too.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Xirus)
       Post #: 32
RE: 54in Mono Build - 7/24/2007 1:10:09 PM
Justaddwata
Status: offline
quote:
ORIGINAL: bentley marshall
But dont all Kiwi's deep down think of themselves as Aussies anyway ?
One of the best gas boat picture sites - http://imageevent.com/justaddwata
I like long walks, especially when they are taken by people who annoy me .....
       Post #: 33
RE: 54in Mono Build - 7/24/2007 1:18:52 PM
STEVE MARSHALL
Status: offline
I have been in OZ for 19 years and still haven't had half my brain removed. ( Might have to get it done soon, due to tax reasons)
(in reply to Justaddwata)
       Post #: 34
RE: 54in Mono Build - 7/24/2007 9:56:11 PM
bentley marshall
Status: offline
looking good bro what size nails come out of the gun imighthave to get one of them for when i get on to the woody cat will be a lot easer then usint pins and weights while the glue gos off
do get any probs with the fraims spliting using that??
       Post #: 35
RE: 54in Mono Build - 7/25/2007 12:31:41 AM
STEVE MARSHALL
Status: offline
10mm nails, with the air pressure turned right down so the nail doesn't go so deep. No splitting so far, just have to make sure it's in the middle of the ply(frames) and not to close to the end.
       Post #: 36
RE: 54in Mono Build - 7/25/2007 3:42:08 AM
Xirus
Status: offline
Sorry it took so long guys. I got tied up in other things. I'm actually on my way out with the Canadian Navy to study as a Marine Engineer.
Here is the frames put in place. I'm going to bolt it back down to the jig tomorrow and start putting the skin on. One problem I ran in to, I have to be extra careful right now because when I got the wood I called my girlfriend on the way back from work and asked her to pick me up some 1/4" ply, regular ply in the hardware section.
Well. Apparently some jerk at Home Depot convinced her that what I need is 1/4 pine because its "better"
She ended up buying it and getting it cut in to the sections I need. This stuff is brittle on the inside with a ply of pine on each side of the pressed chip wood. It was easy to cut but scary because the inside is so brittle.
I was pretty mad but its together and after the skin and fiberglass goes on I wont worry so much.
Here is what I have so far.
       Post #: 37
RE: 54in Mono Build - 7/25/2007 4:21:10 AM
dwr9
Status: offline
Looks good Xirus, I just hope it's strong enough, especially where the motor mounts to the rails. Also be sure to coat the whole inside of the boat with epoxy because I suspect that stuff might not be waterproof. I'd hate to see anyone put that much work into something and have it fall apart. Doug
(in reply to Xirus)
       Post #: 38
RE: 54in Mono Build - 7/25/2007 4:26:06 AM
Xirus
Status: offline
Oh I'll definitely be coating it with either epoxy or polyester resin. as for the engine compartment I plan to put in 2 aluminum rails on the stringers. it wont add much weight besides I plan to put in something with 30+cc's This is my first speed boat and I want it to be fairy cheap. Its also a learning experience for me.
(in reply to dwr9)
       Post #: 39
RE: 54in Mono Build - 7/25/2007 4:44:38 AM
STEVE MARSHALL
Status: offline
Looks good Xirus, Here is my updated photos. Got the bottom sheeting pulled down and glued, now its time for the sides.
Click for fullsize
Click for fullsize
(in reply to Xirus)
       Post #: 40
RE: 54in Mono Build - 7/25/2007 6:00:38 AM
