RE: 54in Mono Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: 54in Mono Build
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: 54in Mono Build - 7/26/2007 12:04:37 PM
STEVE MARSHALL
Status: offline
servo is a GWServo S04BBM 1/4 scale
(in reply to martno1fan)
       Post #: 51
RE: 54in Mono Build - 7/26/2007 11:07:52 PM
ByronRC
Status: offline
quick question. Are you going to describe the painting process? Just curious as to how you go about putting a smooth finish on wood boats.
_____________________________
*boats* boats *boats*
(in reply to STEVE MARSHALL)
       Post #: 52
RE: 54in Mono Build - 7/27/2007 12:21:35 AM
STEVE MARSHALL
Status: offline
ByronRC, with the last boat I sprayed it with a few coats of automotive primer, sanded smooth with 240 grit paper, then another full coat of primer sanded with 400 grit paper, sprayed the gloss enamel (i think i put on about 5 thin coats) sand with 1200 grit paper and then spray with automotive clear coat. It turned out good and its not falling off yet.
(in reply to ByronRC)
       Post #: 53
RE: 54in Mono Build - 7/27/2007 12:24:28 AM
STEVE MARSHALL
Status: offline
here is a pic
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by STEVE MARSHALL -- 7/27/2007 12:28:52 AM >
       Post #: 54
RE: 54in Mono Build - 7/27/2007 2:12:11 AM
dwr9
Status: offline
Steve, an AM radio is usually fine with nitro motors, but Am radios are more prone to interference than FM radios especially in a gas boat. Just be careful til you're sure it's working ok. My boat is a Zenoah, but the best prop I've used so far is an ABC 3014. You could also try an Octura X470/3 or X482. Doug
       Post #: 55
RE: 54in Mono Build - 7/27/2007 2:45:36 AM
bentley marshall
Status: offline
is it finished yet
(in reply to dwr9)
       Post #: 56
RE: 54in Mono Build - 7/27/2007 2:46:20 AM
ByronRC
Status: offline
thanks for the info Steve
(in reply to dwr9)
       Post #: 57
RE: 54in Mono Build - 7/27/2007 3:08:42 AM
STEVE MARSHALL
Status: offline
Look what just arrived. Im'e off to the shed to play.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 58
RE: 54in Mono Build - 7/27/2007 6:11:26 AM
STEVE MARSHALL
Status: offline
Has anyone got a drawing of a coil relocater bracket?. I need to move the coil so it's not hitting the engine rail.
       Post #: 59
RE: 54in Mono Build - 7/27/2007 8:17:31 AM
martno1fan
Status: offline
Byron before you paint anything you first need to coat the hull with epoxy (slow set 3 hour stuff) ,i use an old credit card or similar to spread a thin coat over the outside let it dry then repeat a cpl more times.Then sand smooth,then i primed with filler primer which fills any small imperfections and its great stuff.On the inside you can use a brush to coat with epoxy.Use car spray paints and primers,i used tetrosyl which is cheap and works very well ,once you have given it 3 coats of the filler primer it will be smooth as can be then lightly sand it and spray your gloss ,usually 2 to 3 coats is good.Then apply decals if using and spray over the top with cpl coats of clear coat and make sure its the same make as the paint thats it job done.
im not argumentative im just missunderstood
       Post #: 60
RE: 54in Mono Build - 7/27/2007 8:18:31 AM
martno1fan
Status: offline
quote:
ORIGINAL: STEVE MARSHALL
just cut the rail away a bit if you can steve?
       Post #: 61
RE: 54in Mono Build - 7/27/2007 8:32:23 AM
martno1fan
Status: offline
sorry Steve forgot to say the clone looks good hope it works well for you,was it stage 2 mod ? could be fast if alls well with em cant wait to see it go in your 47" woody asuming your gonna test it out in there before you finnish this new boat?
       Post #: 62
RE: 54in Mono Build - 7/27/2007 9:07:47 AM
bentley marshall
Status: offline
yeah steve i want to see how it gos befor i order one for my 3rd boat but that after i finish the first one and start and finish the second one
       Post #: 63
RE: 54in Mono Build - 7/27/2007 11:17:03 AM
STEVE MARSHALL
Status: offline
Got the clutch and mounts on today. How much of a angle can you run these motors on?. Tomorrow it's back to shaping and glassing the inside of the hull. Here are some pics.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to bentley marshall)
       Post #: 64
RE: 54in Mono Build - 7/27/2007 11:20:16 AM
bentley marshall
Status: offline
duno about the red mounts .... they look a bit out of place rest is good
       Post #: 65
RE: 54in Mono Build - 7/27/2007 12:17:26 PM
martno1fan
Status: offline
looking good steve id keep the motor as level as you can get it so its nice and low in the hull.heres a cpl of pics of ian (w3bbys) boat with his zen mounted in to give you an idea.
Click for fullsize
Click for fullsize
< Message edited by martno1fan -- 7/27/2007 12:20:56 PM >
       Post #: 66
