R8893
Joined: 10/19/2002 From: Cincinnati, OH, Status: online
EF, I am quite certain there must be at least one insulated line. The signal amperage is very small (this makes it possible to use the steel lines which have high resistance) and it is very easy to create a short circuit. I learned this the hard way! Regarding the size of models. The international rules from the FAI (class F4B) allow models of a single engine plane to weigh a maximum of 6 kg. A multi engine model can be 7 kg--hence the 6.85 kg my Henschel weighs. In the USA we can go to 20 pounds, (9 kg) in our Sport Scale class. I participated in the last two World Championships and most of the models were very close to the weight limit. The top Polish competitor managed to build a Fairey Battle with a 2.3 meter span at less than 6 kilos! I sure can't build that light. I am a believer that bigger models fly better, and your question suggests that you do too. However the pull on the lines gets to where it is no longer fun to fly the models. I recently finished a Aichi D3A1 Val dive bomber from the Skyshark kit (no longer available) that I think is a good compromise of wing area, weight, line tension, flyability, and transportability. It weighs 3.4 kg, has a .60 engine, and about 0.5 sq meters of wing area. The Val is the best flying of the scale models I have. The FAI rules also have wing loading rules, but if you went over the limit the model would be so heavy it would not fly well anyhow. The FAI rules also limit line length to 21.5 meters and our rules for other classes are 21.3 meters. Most of our flying fields are not big enough to permit longer lines. Chuck
