SBV2 Pro placement
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Academy Racing (MRC) Support >> SBV2 Pro placement
Page: [1]
Login
SBV2 Pro placement - 7/7/2007 8:33:21 PM
annie_himself
Status: offline
How many ways can the electronics be placed on the buggy? I've only seen the normal SxS setup and no saddle packs, 4x2 setups or anything. Has anyone tried them? Also, can the motor be placed in the front opposite the servo if the top deck was flipped around?
_____________________________
Saldly, 98% of teens have switched to rap music, if you're part of the other 2% that like real hip-hop put this in your sig.
       Post #: 1
RE: SBV2 Pro placement - 7/9/2007 6:41:50 PM
Davey G
Status: offline
Hi,
No the motor cannot be moved forward. 4 x 2 battery setup is achieved by taping the 2 cells in on the opposite side of the 4 cells. The 4x2 setup increases steering, this car already has a ton of steering so most team drivers are sticking with the std 6 cell Side by side setup. Hope this helps, talk to you soon!
Dave Graboski
Custom Painted Bodies: www.myspace.com/3c_grafx
(in reply to annie_himself)
       Post #: 2
RE: SBV2 Pro placement - 7/12/2007 2:50:11 AM
annie_himself
Status: offline
Thank you.
(in reply to Davey G)
       Post #: 3
RE: SBV2 Pro placement - 7/20/2007 5:09:30 AM
Pit Bound
Status: offline
We are running the V2 Pro with the standard 6 cell battery set up on a hard pack surface that is a little loose. No problem with steering at all. If you want steering going into the turn, try the one way on the shaft. We run it and you can hit the corner hard, brake and still steer! Squeeze and it pulls you around the trun...
       Post #: 4
RE: SBV2 Pro placement - 7/23/2007 3:44:05 PM
annie_himself
Status: offline
Ok, good to hear. Thanks again.
(in reply to Pit Bound)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
