noguy
CA, USA Status: offline
quote:
ORIGINAL: FMB42 Hi agent, The HM Axe Ez is a good heli that, meets your needs for a simple indoor and limited outdoor use model. The Esky Lama V3 or V4 (~$100) and the Eflite CX or CX 2 (~$200) would also fit your needs. Be sure to check with your local hobby shop for which brands and parts they carry before you make your choice. Most shops carry carry Eflite helicopters and parts BTW. . The Axe CP as well as the Esky CP (~$125) and Eflite Blade CP (~200) are not well suited for the indoor use you mention. These CP units are also more complicated, and less stable then the coax dual rotor models listed above. However, there are far more upgrades available for these units and they offer superior performance as well. Good luck and good flying! This is good advise. STAY AWAY from "CP" heli's if your are looking "easy to fly, simple, and stable" I'm not sure but I believe that the eflite cx heli's would have the most avaliable accesories. Also keep in mind that the coax heli's are rarely able to fly outdoor. There must be no wind. Good luck with whatever you choose. Noah
_____________________________
up, up and ahh wait not that away!!!
