Fokker DR-1 Balsa USA, HELP HELP
Tower Hobbies
Logged in as Guest
  Printable Version
The NEW JETLEGEND CT-114 Scale: 1/6 CAF & (SNOWBIRD COLOR SCHEME) WE NOW OFFER BU
Seller:  FlyingboyD
Details:   $1,660.00   |  7/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Kit Building >> Kit Manufacturer Direct Support Forum >> Fokker DR-1 Balsa USA, HELP HELP
Page: [1]
Login
Fokker DR-1 Balsa USA, HELP HELP - 7/8/2007 2:16:20 PM
ofirby
Status: offline
Hi,
I have build Fokker DR-1 of Balsa USA 1/4 scale and in test flight I was in problem and CRASH !!!.
The Fokker start "be erect" and move up all the time. Even when I move the remote control set-off to full Down, still the airplane move up. The only way to move it down was close littele bit the throttle.
Before I flight it, i check the balance and it was ok. I build the kit step by step about 7 mounth and use Zenoah 26.
Do you familiar this kind of problem ? do you know the reason of this ?
Thank you in advanced,
Ofir
       Post #: 1
RE: Fokker DR-1 Balsa USA, HELP HELP - 8/31/2007 4:36:59 AM
BULL-RCU
Status: offline
I have a DR-1 and several biplanes. They all tend to want to climb more then single wing planes. I have run into this problem myself when testing planes and usually it's due to Wing incedence. usually positive on the top wing.
_____________________________
Visit my WEB Site www.nobullsales.com Check out my gallery!
(in reply to ofirby)
       Post #: 2
RE: Fokker DR-1 Balsa USA, HELP HELP - 10/2/2007 4:20:47 AM
boothg-3
Status: offline
i have the same aircraft and almost lost it on the test flight because of the problem , it has to do with the lift of the three wings and the light weight aircraft , if you have a computer radio start by setting up a program that mixes in some down elevator at 1/2 throttle and above start with 5% elevator and only at 1/2 throttle and above , i also recommend increasing the downthrust of the engine i set mine to 3 degrees down and 3 degrees right thrust , and it still requires a little elevator mixing to throttle input , the reason is as teh air speed increases so does the lift of the wings , nick ziroli actually has the leading edge of the horizontal stab a few degrees higher than the trailing edge to offset thsi condition on his DR-1 try it and it will fly fine i have had mine now for 6 years and dont forget right rudder on take off
(in reply to BULL-RCU)
       Post #: 3
RE: Fokker DR-1 Balsa USA, HELP HELP - 10/2/2007 7:49:29 AM
ofirby
Status: offline
I increase the downthrust of the engine to 4 degrees down and 3 degrees right thrust, Also I increase stabilizer to 2 positive degrees and the highest wing also to 2 positive degrees and its helps a lot. Finely I could fly the Fokker-DR as real plane.
(in reply to boothg-3)
       Post #: 4
RE: Fokker DR-1 Balsa USA, HELP HELP - 10/3/2007 4:42:52 AM
boothg-3
Status: offline
i wouldnt increase the incidence of the upper wing leave it at zero or even give it 1 or 2 degrees of negative , by having negative incidence in the upper wing it continue to have lift after the others stall at low speed ,with positive incidence it will stall before the others
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.454RCU1
