jester409
TN, USA Status: offline
quote:
ORIGINAL: daveuk2 HI Jester, I too am very impressed with this little heli, I would prefer some Expo on the controls as they are far too twitchy, I am still struggling with the lail turn/drift you describe, I thought I'd tracked blades perfect with still a drift problem.... wish I could sort it. I think the motors fitted do not always match and then you get this problem. Other than that I really like it. On the new versions they need an adjustment between the motors. I will agree to a degree on the Expo, but the touchy controls are actually starting to grow on me, as it adds a bit more thumb difficulty to flying a mundane coax. As far getting the tail to hold, you may be on to something with the unbalanced motors. Make sure that neither motor has un-needed drag caused by a gauled main gear or one of the shafts being out of align/bent. If all is good with everything else, maybe a new set of motors will solve the problem. Good luck.
