RE: Disposable epoxy mixing palets
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: Disposable epoxy mixing palets Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Disposable epoxy mixing palets - 7/13/2007 8:34:12 AM
SMUGator
Status: offline
I build on glass and just mix right on the surface and scrape off the leftovers.
_____________________________
Currently building a 1/6 Scale F4U-1A Corsair (BuNo 17777) and finishing a TF 1/8 Corsair
(in reply to Wblakeney)
       Post #: 26
RE: Disposable epoxy mixing palets - 7/13/2007 10:08:07 AM
cowana
Status: offline
quote:
ORIGINAL: styk
I never realised till i started reading this forum ... Diepers (Nappies)...
What part of the forum did you read that in?
(in reply to styk)
       Post #: 27
RE: Disposable epoxy mixing palets - 7/13/2007 12:39:08 PM
styk
Status: offline
quote:
ORIGINAL: cowana
quote:
ORIGINAL: styk
There's an american guy in our club and he says that some of our members ought to be wearing them
(in reply to cowana)
       Post #: 28
RE: Disposable epoxy mixing palets - 7/20/2007 2:33:55 AM
Bipe Flyer
Status: offline
quote:
ORIGINAL: styk
Thanks for that Bill.Although we all speak English I never realised till i started reading this forum that there is a lot of things we have different names for i.e. Gas (petrol) Diepers (Nappies) Get the drift
All the best
Styk
In Canada we understand and use a mix of both UK and US words, but nobody understands "It's a braw bricht moonlicht nicht, the nicht".
1/2A all the way!
Club Saito #151
(in reply to styk)
       Post #: 29
RE: Disposable epoxy mixing palets - 7/20/2007 2:36:08 AM
Bipe Flyer
Status: offline
For mixing epoxy, I use a small writing pad that is for taking phone messages. Just tear off the used sheet and throw/toss it in the garbage/trash/bin.
1/2A all the way!
Club Saito #151
(in reply to Bipe Flyer)
       Post #: 30
RE: Disposable epoxy mixing palets - 7/20/2007 3:44:21 AM
Bruno Stachel
Status: offline
"I use the plastic lids of ice cream containers. Cured epoxy just peels off. I stir them with those wooden sticks you get for stirring coffee in supermarkets (Tesco), and coffe shops. I must have a ccumulated well over 100 of them by now."
Cowana,
I do the same thing with 6 oz yogurt cup lids. I've saved over a 100 of them. But I'll use one over and over by letting the epoxy cure, then peel it right off. However, the yougurt we buy now comes without the lid, just a foil seal. Something about be enviromentally friendly.
< Message edited by Bruno Stachel -- 7/20/2007 3:48:26 AM >
       Post #: 31
RE: Disposable epoxy mixing palets - 7/20/2007 4:36:35 AM
frenchie79
Status: offline
I use phone message notes (3x5)-taken from my secretary- cheap and dollar tree has popcicle sticks and toothpicks for a buck. Mixing more-use those fruit containers with the peel off lids.
Frenchie #193
(in reply to Atarget1)
       Post #: 32
RE: Disposable epoxy mixing palets - 7/20/2007 11:05:09 AM
cowana
Status: offline
quote:
ORIGINAL: Bipe Flyer
It is?!?!?!?!?!?! Oh my god! Run!!!!
< Message edited by cowana -- 7/20/2007 11:06:19 AM >
       Post #: 33
RE: Disposable epoxy mixing palets - 7/26/2007 12:31:23 AM
kahn41
Status: offline
I also use condiment cups from big lots 2 dollars for 250 and a box of popsicles stick's from the hobbie shop, 500 for three bucks. a roll of 2" wide masking tape works good to...
(in reply to SST)
       Post #: 34
RE: Disposable epoxy mixing palets - 7/26/2007 12:48:13 AM
Insanemoondoggie
Status: offline
Mixing on paper is not a good idea or anything that can asorb the chemicals in the epoxy. Same goes for body filler or any 2 part mix.
(in reply to kahn41)
       Post #: 35
RE: Disposable epoxy mixing palets - 8/9/2007 3:46:21 AM
Beaver Lover
Status: offline
Have you ever seen those 3x3 Post-It notes that come in a stack about 5 inches high? That's what I use. Before that, I was using old AMA magazines.
(in reply to Insanemoondoggie)
       Post #: 36
RE: Disposable epoxy mixing palets - 8/10/2007 2:19:36 AM
Tall Paul
Status: offline
Old photographs.. the 4x6 size..
Mark two circles using a coin.. dime, quarter, or bottom of a bottle cap, pill bottle, or container.
One for part 1, one for part 2. Fill equally, mix, use, toss.
Sparky Paul
http://www.angelfire.com/indie/aerostuff
(in reply to Beaver Lover)
       Post #: 37
RE: Disposable epoxy mixing palets - 8/10/2007 2:19:12 PM
BillyGoat
Status: offline
quote:
ORIGINAL: Beaver Lover
.... Before that, I was using old AMA magazines.
I'm glad somebody found Model Aviation good for something.
       Post #: 38
RE: Disposable epoxy mixing palets - 8/10/2007 6:25:01 PM
Hareman
Status: offline
I go to our local Sam's club around noon and get the used sample cups they give samples of food in (condiment cups?) It embarasses my wife when I ask the vendors if I may go thru their trash cans, but they are happy to let me have all I want. I carry a plastic grocery bag in my pocket when I go in and leave my wife to shop while I scavenge!
(in reply to BillyGoat)
       Post #: 39
RE: Disposable epoxy mixing palets - 8/16/2007 9:44:14 PM
OzMo
Status: offline
ketchup paper cups from the burger joint. mix with an old flat blade pocket size screw driver that wipes or scrapes off easy. its flat and works as a spatula for fine placement.
Yes dear, I did glue my hand to the airplane to keep from dropping it.
       Post #: 40
RE: Disposable epoxy mixing palets - 8/16/2007 11:00:37 PM
sscherin
Status: offline
I've been using the clear plastic liquid laundry detergent measuring cups and whatever scrap wood is laying around..
Just throw the stick in the cup when finished.. the epoxy will cure and toy can pull it out with the stick..
re use them over and over again.
Margarine tub lids also work great and can be reused.
AMA #163334
There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance
       Post #: 41
RE: Disposable epoxy mixing palets - 8/21/2007 7:42:30 AM
landing-gear
Status: offline
We had some vinyl flooring left over after we built our house years ago so I have a few bits cut to 10cm x 10cm once the epoxy drys I flex the vinyl and the dried glue peels off.
"Oh bugger who put the earth there!"
"This is gunna hurt"
(in reply to sscherin)
       Post #: 42
RE: Disposable epoxy mixing palets - 8/21/2007 11:53:14 PM
