Disposable epoxy mixing palets
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Disposable epoxy mixing palets
Page: [1] 2 3   next >   >>
Login
Disposable epoxy mixing palets - 7/9/2007 11:18:34 AM
Atarget1
Status: offline
I find that I mix small amounts of epoxy during my kit building.So to save money and the need to look for some place to mix the stuff I use index cards.The 3x5 cards that are used for receipes and such.I mix the amount of epoxy right on a card and dispose of it when done.The come in packs of 3-5 hundred,should last quite awhile for most and cost under a dollar.
       Post #: 1
RE: Disposable epoxy mixing palets - 7/9/2007 11:30:33 AM
piper_chuck
Status: offline
I use the plastic tops from quart size sherbet containers. You can make several small batches on each side. Once it's cured if you bend the top a bit, the epoxy peels right off. You can also use both sides.
_____________________________
AMA 87959, IMPBA 19650 CD, IBDBG #2, local 12
There's A Reason I'm Behind You. You're About To Be Lapped!!!
(in reply to Atarget1)
       Post #: 2
RE: Disposable epoxy mixing palets - 7/9/2007 11:37:33 AM
SST
Status: offline
I buy 1&2oz condiment cups, and craft sticks by the bag & box. I also use single tube coffee stirrers for aileron torque tubes and for wire pushrod tubes...
Rule #1: Always know when to get out of Dodge.
Rule #2: Always know HOW to get out of Dodge.
(in reply to piper_chuck)
       Post #: 3
RE: Disposable epoxy mixing palets - 7/9/2007 11:38:28 AM
rwright142
Status: online
I use the paper bowls you get at fast food restaurants for your ketchup and mix using sticks made from scrap balsa.
If I need to mix more than that (not very often) then the plastic lids on spray paint cans work. Once the leftover epoxy has cured you can squeeze the lid and the epoxy peels right out.
< Message edited by rwright142 -- 7/9/2007 11:39:47 AM >
In the works: 1/6 Scale F4U Corsair
       Post #: 4
RE: Disposable epoxy mixing palets - 7/9/2007 12:37:42 PM
Flyboy Dave
Status: online
....I use the bottom of soda pop cans to mix epoxy most of the time.
FBD.
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to rwright142)
       Post #: 5
RE: Disposable epoxy mixing palets - 7/9/2007 12:46:10 PM
heli_Rod
Status: offline
I use old note pads that have been used up for writing. POST-IT note pads work great too. Just tear it off and throw away when done.
Rod
AMA# 113287, Amateur Radio WA9H, Synergy N9, Fury Extreme 90, Stinger 50, T-REX 450SE V2, JR & Spektrum Radios
(in reply to Flyboy Dave)
       Post #: 6
RE: Disposable epoxy mixing palets - 7/9/2007 1:24:12 PM
da Rock
Status: offline
The index cards will also teach you something.
Mix some 5-minute on the top card of the stack. When it's cured, peel it off. Didn't penetrate enough to stick did it.
Now mix some 15-minute. Won't peel off will it.
Now mix some 30-minute. Sticks the top card to the next one.
BTW, a box of toothpicks sits next to the stack of cards. They work for over half the epoxy jobs.
Also, a stack of 2-ounce "drug" cups from the Drug Store costs a couple of dollars. They're marked like measuring cups. Great for doing Epoxy Surfacing Resin mixes. The last sleeve of them I bought a couple of years ago still has a few left in it.
(in reply to heli_Rod)
       Post #: 7
RE: Disposable epoxy mixing palets - 7/9/2007 2:27:43 PM
styk
Status: offline
I use an old 3"x3"ceramic tile (dont know what you call them in the States) for mixing epoxy Good hard surface for mixing on and then you just wipe it clean after use Last forever
(in reply to da Rock)
       Post #: 8
RE: Disposable epoxy mixing palets - 7/9/2007 2:39:44 PM
flyalot
Status: offline
I use the insert cards that are in all magazines. These inserts ar printed on a heavy weight paper (70#/ream if memory serves me right ). They also work well for small templates. No cost , and you will never run out as each magazine you buy will supply you with several. Joe
(in reply to styk)
       Post #: 9
RE: Disposable epoxy mixing palets - 7/9/2007 3:05:52 PM
bear 57
Status: online
Hey, how about my system. I use an unwanted, glossy type of magazine.
I mix right on to the page. I get several mixes per page. When one page is used up I just tear it off and go to the next.
Works great for me.
bear57
(in reply to flyalot)
       Post #: 10
RE: Disposable epoxy mixing palets - 7/9/2007 5:13:56 PM
huggins
Status: offline
quote:
ORIGINAL: bear 57
Works great for me.
bear57
This is what I do as well. However, I don't worry about it being a "glossy" type. I use an old TV Guide which is mostly newsprint. Doesn't seem to make any difference. Get a few and you will probably be set for life.
Mike
(in reply to bear 57)
       Post #: 11
RE: Disposable epoxy mixing palets - 7/9/2007 8:24:23 PM
bkdavy
Status: offline
Try using Waxed Paper. Its cheap for a roll at the grocery store, and one roll will probably last a lifetime. You can choose the size you want for the amount you're mixing, it stays flat so it doesn't heat up, and you can also use it to smooth over microballoon and epoxy fillers.
Brad
(in reply to huggins)
       Post #: 12
RE: Disposable epoxy mixing palets - 7/9/2007 9:20:38 PM
cstevenpeterson
Status: offline
I have accumulated 1000's of business cards throughout my career. The companies I worked for would always provide a 1000 at a clip and I never used them all, so I just took them with me when I moved on and now they come in handy when mixing small amounts of epoxy. Also, they are thick enough not to worry about "soak through". For larger volumes, I use the plastic mixing cups.
Steve
(in reply to bkdavy)
       Post #: 13
RE: Disposable epoxy mixing palets - 7/9/2007 9:27:29 PM
heli_Rod
Status: offline
It is amazing what modelers will use to acomplish a task. We are indeed a innovative group of people.....LOL....Nothing goes to waste!
Rod
(in reply to cstevenpeterson)
       Post #: 14
RE: Disposable epoxy mixing palets - 7/9/2007 11:02:24 PM
rorywquin
Status: offline
quote:
ORIGINAL: styk
A true Scotsman
(in reply to styk)
       Post #: 15
RE: Disposable epoxy mixing palets - 7/10/2007 3:10:12 AM
Redback
Status: offline
My system beats the lot!
I use the lids of 4 litre ice cream containers. To ensure a good supply I have to eat the ice cream. It's tough, but it has to be done!
Terry
(in reply to rorywquin)
       Post #: 16
RE: Disposable epoxy mixing palets - 7/10/2007 11:45:37 AM
huggins
Status: offline
quote:
ORIGINAL: Redback
Terry
Same goes for all the popsicles I have to eat to keep an adequate supply for mixing!
Mike
(in reply to Redback)
       Post #: 17
RE: Disposable epoxy mixing palets - 7/10/2007 11:56:04 AM
