RE: Byron P-51 Mustang
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Byron P-51 Mustang
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: Byron P-51 Mustang - 12/30/2007 4:52:18 AM
grbaker
Status: offline
blkmerlin1
I have a very old Byron Mustang (one piece wing) with the direct drive mount (G62).
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by grbaker -- 12/30/2007 5:14:14 AM >
_____________________________
Gary Baker
(in reply to blkmerlin1)
       Post #: 76
RE: Byron P-51 Mustang - 12/30/2007 5:04:06 AM
Carlos G
Status: offline
Hi BlkMerlin,
Sorry, I havent seen any in a while. Most of those guys are doing other things now and those planes are long gone.
It was sort of a case of "Dueling Wallets" as it were. Each guy was trying to out do the other with the biggest , baddest model or the most gadgets you could have on the flight line.
I was sort of the engine guy and help them get the beast running. It was well beyond my budget to have those types of models but, the guys from time to time needed help keeping them flying or sorting out teething problems and so I helped out.
It was fun
Carlos G.
       Post #: 77
RE: Byron P-51 Mustang - 12/30/2007 6:45:03 AM
Wayne22
Status: offline
[quoteI am using 2 hs125mg(50oz @ 6volts) wing servos for the elevator mounted in the elvator surface ][/quote]
Those servos are way too small for a giant scale vibrating p-51. The gear teeth are microscopic and it will not take much to break a few of them off. go bigger....much, much bigger.
All I ask is for a chance to prove that money can't make me happy......
(in reply to Carlos G)
       Post #: 78
RE: Byron P-51 Mustang - 12/30/2007 8:43:58 AM
blkmerlin1
Status: offline
Thanks Carlos and wayne I was in the shop today redoing the horizontal filling the holes back with new foam I am going to use 2 elv servos with carbon fiber rods in the fuse
Thanks again for the advice.
(in reply to Wayne22)
       Post #: 79
RE: Byron P-51 Mustang - 12/30/2007 8:48:40 AM
blkmerlin1
Status: offline
GRBaker how was the flight of the plane after moving the weight closer to the nose thanks for the photos and info.
       Post #: 80
RE: Byron P-51 Mustang - 12/30/2007 1:50:04 PM
grbaker
Status: offline
blkmerlin1
This Mustang was originally built with the direct drive and a G62. It was probably 8 - 10 years old when I got it from a friend of mine. It flies like a trainer @ 25 pounds. No tendancy to nose over once I got the hang of flying a taildragger (all my other warbirds were trike gear: P-39, F-4, T-38). I flew it with the same Zinger 20X8-14 prop for a couple of years. Most takeoffs were accomplished with about half thottle and then a smooth transition to full. It slows down real well with the flaps. I never tried to 3 point land it, just set down reasonably slow on the mains and then let the tail come down.
I sold it 6 or 7 years ago but had the opportunity to buy it back a couple of years ago. It is not in flying shape and I have been too busy with work and other projects to restore it to flying condition. It needs quite a bit of work and lots of new retract parts. Servos are probably the original units installed when it was built (Futaba S-148s all around). Hopefully 2008 will be a better year for my RC hobby and I'll get it and my 1/5 scale P-39 flying again.
Gary Baker
       Post #: 81
RE: Byron P-51 Mustang - 12/30/2007 5:43:15 PM
HUNTERANDJEFF
Status: offline
Bkmerlin1, How close are you to paint? Call me when you decide to fly it. I am a long way to finish. Right now, I don't even have the retracts or the gear pants!! But, I do have ideas on how to get the stuff. It will take weeks though now not months. I heard that our planes are really loud, so it is a good thing that our field is where it is huh?
Jeff
JeffThe only yard sales I go to is when I pick up my plane from all over the runway!!!!
Revver bro #191
(in reply to grbaker)
       Post #: 82
RE: Byron P-51 Mustang - 12/30/2007 7:42:14 PM
blkmerlin1
Status: offline
thanks grbaker and good luck this next year. HUNTERANDJEFF I am in the process or filling and sanding the wing is ready for primer and the fuse will be ready shortly I did change the color sceme I am doing Bud Andersons Old Crow waiting for paint that I ordered from Nelsonhobby need a couple of servos and a retract servo for the flaps and misc control parts I have to figure out the sequence for the tail gear doors I have to remember were I saw a hobby shop that sells small piano hinges.But its coming along.How about yours were are you at in the project?
(in reply to HUNTERANDJEFF)
       Post #: 83
RE: Byron P-51 Mustang - 12/31/2007 1:55:52 AM
Scott McCrory
Status: offline
Jeff, I have an old set of retracts for the early style one piece wing. They are air up, spring down, with the old control valve and I also have the inner and outer aluminum halves of the gear doors. Let me know if you are interested. Here's some pics of my old style one piece wing before and after the aileron linkage failed, and my new style plug in wings. Hoping to maiden it this summer.
Scott
[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 84
RE: Byron P-51 Mustang - 1/3/2008 2:15:33 AM
SnakeBT6
Status: offline
First post here..
I have an unbuilt Byron as well..well its time for the meat and potatoes part..
Im considering (more or less decided really) a DA50 with scale exhaust..Im not a big fan of the visible head..
Also Ive noticed that alot of the Byrons have a "nose high tail low" stance...not sure how that correlates to the real airplane, but as my kit doesnt have any landing gear, Im going with Sierra Precision, for mains/tail as well as tires/rims..
Other then some nice details/finishing touches (full cockpit, body fairings, scale exhaust, detailed wheel wells, DA 50, etc...) Ill build it per plans, although I think Im going to mount the aileron servos outboard in the wing..not fan of that tube rail thing..
I am having trouble reaching Iron Bay..Not sue if its the holidays or what..Id like to incorporate a sliding canopy but not sure of anyone other then I B that makes one for that kit/canopy..
< Message edited by SnakeBT6 -- 1/3/2008 2:28:21 AM >
(in reply to Scott McCrory)
       Post #: 85
RE: Byron P-51 Mustang - 1/4/2008 11:41:46 PM
blkmerlin1
Status: offline
I emailed IronBay the other day and recieved a reply might be just the holidays.
(in reply to SnakeBT6)
       Post #: 86
RE: Byron P-51 Mustang - 1/5/2008 1:40:11 AM
Ram-bro
Status: offline
so are they open for model airplane business or what?
       Post #: 87
RE: Byron P-51 Mustang - 1/5/2008 2:23:00 PM
blkmerlin1
Status: offline
I emailed and asked if they had parts available and he said send him part #'s and that they had all the repro parts so I would say yes.
(in reply to Ram-bro)
       Post #: 88
RE: Byron P-51 Mustang - 1/17/2008 6:42:25 PM
solarshot23
Status: offline
I sent John at Iron Bay an E-mail and haven't heard back from him....Over a week now. As far as part #'s his web site won't let me down load the pages needed.
If anyone has an unbuilt kit they want to sell let me know.
Wayne
Easy Does It But Definately Do It !
       Post #: 89
RE: Byron P-51 Mustang - 1/17/2008 9:58:36 PM
masteromodels
Status: offline
ok i just got my new g-38 coil today but i just cannot mount it yet they sent it with a very short wire that won't reach the spark plug and there is no plug at the end of the wire either. anyone have any ideas on how to extend the wire and add the plug??? it cost $126.00 for just the coil.
thanks bob
p40bob
(in reply to solarshot23)
       Post #: 90
RE: Byron P-51 Mustang - 1/18/2008 1:21:47 AM
nine o nine
Status: offline
Wayne, I sent you an E-mail today about my NIB P-51. Mitch
       Post #: 91
