Wayne22
AB, CANADA Status: offline
Don't get your hopes too high for Scalemasters...it is way, way, way, way, way, way off scale. However, it looks fabulous with that big 4 bladed prop, and flies like a giant (albeit heavy) trainer..... Depending on your engine choice, the cylinder head usually sticks out below and to one side of the cowling, right in front of the wing...it is hardly noticeable. The engine is working pretty hard and you need to get lots of cooling air around it anyways. I never found it particularly difficult to work on, although it is a complicated plane with lots of stuff inside - some of which vibrates loose fairly regularly. You get used to it and know where everything is located in pretty short order.......
_____________________________
All I ask is for a chance to prove that money can't make me happy......
