twomanytoys
Well with the bigger tires and added torque from the motor it will easliy break the 65mph mark and get there quick. The Picco 21 p9r turns 36000 rpm's @ 2.7 hp while the picco 26 turns at 32000 rpm's @ 2.4hp. .Even the picco 21 p7 has the same hp as the 26 but with slightly lower rpms. So here yopu have smaller cc engines with the higher hp and higher rpm's than the 26max. Most of the ofna med blocks have more hp and higher rpm's. The hyper .21 has 2.7 hp at 38000 rpm,s. The force 28 turns @ 38000 rpm,s with 2.7hp and the force 32 is a huge 3+hp @ 38, 000 rpm,s. So as you can see the picco .26 max pretty much has the lowest rpm's and the lowest hp of all the bigger ofna motors.
_____________________________
J et A ssisted T ake O ff
