ULTRA SpadSitk building thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> ULTRA SpadSitk building thread
Page: [1]
Login
ULTRA SpadSitk building thread - 7/9/2007 11:41:42 PM
Milcent
Status: offline
I am starting a new SPAD. This will be my first gas engine. I choose the zenoah 26cc.
Since i can't find large pipe for the fuselage i decided to use plywood to build the engine support in the fuselage. Also i have no coroplast as long as 56 inches, the only lenght we have here is around 32 inches. Thus is will use two piece of coros and i will join them with carbon or fiber.
I will post pictures tomorrow i think with the first pieces of the fuselage.
       Post #: 1
RE: ULTRA SpadSitk building thread - 7/10/2007 4:09:13 PM
Milcent
Status: offline
Some pictures of the built.
Since i don't have 56 inches coro lenght i will glue two pieces with fiber.
Also the replace the gutter pipe with plywood for building the engine support.
More pictures to come.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Milcent)
       Post #: 2
RE: ULTRA SpadSitk building thread - 7/11/2007 2:18:01 AM
flybug
Status: online
Milcent, great progres keep it coming.
_____________________________
My grandfather always said that living is like licking honey off a thorn. - Louis Adamic
       Post #: 3
RE: ULTRA SpadSitk building thread - 7/11/2007 2:56:59 PM
TruBlu02
Status: offline
Awesome! I planning on building one of these soon as well. I will be using a 45cc Thor engine though as I like a little bit of a lopsided power to weight. I want my Ultra Spadstick to hover!
(in reply to flybug)
       Post #: 4
RE: ULTRA SpadSitk building thread - 7/11/2007 8:12:01 PM
Milcent
Status: offline
Some picture of a very usefull tool. I did it to create aileron by removing upper flute.
I use it to bend more easily the fuselage around the engine support made of plywood. I can remove flute in one movement, it is clear and clean.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to TruBlu02)
       Post #: 5
RE: ULTRA SpadSitk building thread - 7/11/2007 11:47:44 PM
flybug
Status: online
Milcent, what is the white material in the engine box (firewall) and can you post side shot of the fuselage?
       Post #: 6
RE: ULTRA SpadSitk building thread - 7/12/2007 8:23:07 AM
Milcent
Status: offline
Hello flybug,
the white material is a cut board used in the kitchen to cut meat or vegetables. it is 1cm thick and i will use to piece of it to do the firewall. It will be in the plywood box and screwed to it.
Here are some shots of the fuselage side shots. Is it ok ?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 7
RE: ULTRA SpadSitk building thread - 7/12/2007 6:13:09 PM
flybug
Status: online
Milcent, many thanks for the pics, clever idea to use that cutting board . Your project is looking very good by the way.
Edit: I like the way you joined the coro towards the end of the fuse, almost seemless
< Message edited by flybug -- 7/12/2007 6:14:34 PM >
       Post #: 8
RE: ULTRA SpadSitk building thread - 7/18/2007 6:13:46 AM
mikenlapaz
Status: offline
Milcent
What is the thickness of the plywood your using for firewall mount and doubler? Looking good, mine came in tail heavy with Ryobi ,17.5#
''A government big enough to give you everything you want, is big enough to take away everything you have.'' Thomas Jefferso
       Post #: 9
RE: ULTRA SpadSitk building thread - 10/27/2007 1:04:55 PM
Xairflyer
Status: offline
How is the ultra spad progressing, about to start mine
www.letterkennymodelflyingclub.com
(in reply to mikenlapaz)
       Post #: 10
RE: ULTRA SpadSitk building thread - 10/29/2007 6:40:12 AM
OzMo
Status: offline
quote:
ORIGINAL: Milcent
nice . that is a variation af a standard SPAD tool usually seen as a pulled rig and it makes some difference which way the blade bevels are set. but I can see that using it as a pushed tool would be fine. I keep giving mine to newbys! a piece of sanded yard stick works great too.
Yes dear, I did glue my hand to the airplane to keep from dropping it.
       Post #: 11
RE: ULTRA SpadSitk building thread - 10/29/2007 7:22:16 AM
mikenlapaz
Status: offline
I like to remove the bottom of a flute. The ones with the top cutout
just more dust.
(in reply to OzMo)
       Post #: 12
RE: ULTRA SpadSitk building thread - 11/4/2007 4:59:44 PM
K.rashenburn
Status: offline
Nice Build , keep us posted
"It ain't busted till it bursts into flames"
       Post #: 13
RE: ULTRA SpadSitk building thread - 11/4/2007 7:05:16 PM
spad4mebaby
Status: offline
Mine only get dusty after a crash. They are really dusty or Boken, needing a bandaid.
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
