Can You Slow Down a Servo?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Can You Slow Down a Servo?
Page: [1] 2   next >   >>
Login
Can You Slow Down a Servo? - 7/10/2007 1:29:28 PM
rwright142
Status: offline
I have a project I am working on where I need to slow down the speed of a servo. If possible, I would like to only slow it down when it is initialized. I do not mean by using the transmitter, but rather something internal to the servo.
Has anyone done this or is this even possible?
Maybe there are certain types of servos that can do this?
< Message edited by rwright142 -- 7/10/2007 1:30:48 PM >
_____________________________
In the works: 1/6 Scale F4U Corsair
       Post #: 1
RE: Can You Slow Down a Servo? - 7/10/2007 1:51:28 PM
Dsegal
Status: online
You can use a Jomar "gear and door sequencer". Go to http://www.emsjomar.com/SearchResult.aspx?CategoryID=6
Dave Segal
(in reply to rwright142)
       Post #: 2
RE: Can You Slow Down a Servo? - 7/10/2007 1:51:34 PM
Jburry
Status: offline
many digital servos will allow the rate to be programmed...
Revver Bro. #220
       Post #: 3
RE: Can You Slow Down a Servo? - 7/10/2007 2:06:17 PM
exeter_acres
Status: offline
Yep....
http://electrodynam.com/rc/EDR-122/index.shtml
Extreme Flight RC tech support
IMAC members, Thanks for voting!
(in reply to Jburry)
       Post #: 4
RE: Can You Slow Down a Servo? - 7/10/2007 2:08:51 PM
rwright142
Status: offline
Dsegal,
Do these control the initial movement? I have a way of slowing the servo down when I need it to move, but what about when power is initially turned on? Will your suggestions also slow it down at that time? I'll check the website for more info.
Jburry,
I'll research those too.
Thanks!
       Post #: 5
RE: Can You Slow Down a Servo? - 7/10/2007 2:13:41 PM
rwright142
Status: offline
quote:
ORIGINAL: exeter_acres
Yep....
Thanks, another great product, but does it slow down the initial movement (when powered on)?
I've emailed several people now and hopefully I'll find a product that will work.
Thanks again.
(in reply to exeter_acres)
       Post #: 6
RE: Can You Slow Down a Servo? - 7/10/2007 2:54:11 PM
jetmech05
Status: offline
sounds like expo might be what you're looking for
       Post #: 7
RE: Can You Slow Down a Servo? - 7/10/2007 3:21:43 PM
rwright142
Status: offline
expo?
(in reply to jetmech05)
       Post #: 8
RE: Can You Slow Down a Servo? - 7/10/2007 5:50:15 PM
Scar
Status: offline
quote:
ORIGINAL: rwright142
expo?
Yes, Exponential. Programming that comes with some radios. The idea is to reduce the stick-to-servo motion ratio, near the zero point. Is that what you want?
If not, perhaps you could make a full explanation of what you are controlling and how you want it to act, perhaps with mention of the names & designations of the model, the radio, the servo, and any other information.
My spelling isn't good enough to post grafitti.
       Post #: 9
RE: Can You Slow Down a Servo? - 7/10/2007 6:33:57 PM
rwright142
Status: offline
I thought that's what he meant, but I am asking if there is a way to slow the servo down when it initially has power connected.
For example, you turn on your transmitter, then you turn on the receiver. When you turn on the receiver, the servos "center" themself (for lack of a better term). This action is fast. I need to slow this down.
Sorry, I thought I explained what I wanted to do - duh... brain fart. This is why I am asking these questions:
In my Corsair the wings will fold. If I have the wings up but the transmitter switch is in the 'spread the wings' position and I turn on the tx and rx, the servos will quickly attempt to move the wings to the spread position, possibly damaging the wings.
If I have the servo speed adjusted to a slower speed then if/when I make that numskull mistake it won't hurt anything. Obviously, I could just put a note, tape, banner, etc on the transmitter reminding myself to check the switch position before powering everything on, but....
< Message edited by rwright142 -- 7/10/2007 6:36:13 PM >
(in reply to Scar)
       Post #: 10
RE: Can You Slow Down a Servo? - 7/10/2007 8:12:27 PM
scratchonly
Status: offline
Check the tansit time on retract servos. I believe they are much slower than regular servos.
Real planes have two wings and round engines
       Post #: 11
RE: Can You Slow Down a Servo? - 7/10/2007 9:11:46 PM
Dsegal
Status: online
Sorry, but I have no further information on this gadget.
Dave Segal
       Post #: 12
RE: Can You Slow Down a Servo? - 7/10/2007 9:40:22 PM
daveopam
Status: offline
I don't know what TX you have. If you have a Futaba 9C you could set a mix to itself for this action. When the 9C is turned on if the mix is active you get a warning. If you get the warning flip the switch and then turn the plane on. If you don't get the warning all is fine. Like I said I don't know what TX you have but others could also have this setup.
David
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
(in reply to Dsegal)
       Post #: 13
RE: Can You Slow Down a Servo? - 7/10/2007 10:07:35 PM
j.duncker
Status: offline
You could put a switch in line to the servo on that channel.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
(in reply to daveopam)
       Post #: 14
RE: Can You Slow Down a Servo? - 7/10/2007 10:30:52 PM
TLH101
Status: offline
A few options:
http://www.rc-cam.com/ldtastic.htm
http://www.welwyn.demon.co.uk/sslow/sslow.htm
http://smservices.net/acatalog/On_Board_Units.html
http://www.hobby-lobby.com/servos.htm (near the bottom of the page)
http://www.dionysusdesign.com/product_info.php?products_id=164
http://members.iinet.com.au/~lextron/models/slow.html
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
(in reply to j.duncker)
       Post #: 15
RE: Can You Slow Down a Servo? - 7/11/2007 11:45:15 AM
rwright142
Status: offline
quote:
ORIGINAL: daveopam
David
I'll have to check into this, thanks.
       Post #: 16
RE: Can You Slow Down a Servo? - 7/11/2007 11:46:25 AM
rwright142
Status: offline
quote:
ORIGINAL: TLH101
A few options:
Nice links, thanks. I have not seen several of these.
(in reply to TLH101)
