23rd_Fox
NJ, USA Status: offline
Hi all, I'm new to the hobby, but I'm very anxious to get up and running with it. I bought a Tower Trainer 40, but I've only lifted off for a second or two, but not at an AMA club. In retrospect, that was a stupid decision, because apparently the elevator wasn't airworthy. I epoxy'd it, and it should be fine for next weekend, but that's beside the point I just bought an old Model Rectifier Corporation foam trainer with a little Enya brand .15 size engine that I saw on craigslist. It came with a couple of spare wings, a 4-channel Futaba AM radio + servos, a flight box with a bunch of crap (including a power panel, servo parts, glow starter, etc.). And was missing the Rx battery, although I'm sure my other plane's battery would work in it. Anyway, I only paid 50 dollars for the whole package, and I think I got a decent deal even though I know I have a lot of work to do on it. I assumed the that the engine wouldn't work out of the box, and I was right: I squirted some fuel into it and clipped the glow ignitor onto it, but it didn't fire. I turned it upside down, flipped the prop, and it squirted reddish oil crap right out the side of the cylinder head Turns out the head was loose, so I took the opportunity to partially disassemble it. I removed the muffler, the head, took the prop off and washed everything out with soap and water. I wiped it all down, put some after-run in it so it wouldn't rust, and let it dry the rest of the way on its own. That evening, I put it back together and swapped out the glow plug with one that's known to work. I put some fuel directly into the shaft and it lit right up and spun for a second or two before running dry again. Now, the problem I'm facing is that the throttle seems to be completely stuck! I tried sticking a little wooden skewer in and putting pressure on the opening, since it's set to idle right now, but it didn't budge. Any ideas on how to get this thing open?
