RE: CERMARK F-18 HORNET, BUILT IT BETTER, STRONGER,... - 2/15/2008 4:32:20 AM
kochj
MN, USA Status: offline
Perhaps you are correct..... The weight that you see is incorrect, as the muffler is not as heavy as posted.... My muffler is shaved thin and weighs little...... I had thought about use of a tuned muffled pipe/header..... And yes the 9500rang is very simular to a 4-stroke........ But I have seen some very very fast 4-strokes on GP little toni's that have handidly beat the .90 2 stroke...... I am sure that it can be proped correctly,,,, but I do see where you are going with this!!... Thank you for the reply.. This may cause me to rethink my use of a 1.20 AX on the GP minnow w/a tuned pipe!.... My way of thinking is that "2-stroke + more RPM's = more power and speed" But I think that I will get minimal increase in speed when comparing to a .90 Jet engine!... Probly doesn't compare.... Justin
_____________________________
Winning isn''''t everything, it''''s all there is.
