bob27s
OH, USA Status: offline
An 11x7 should easily be turning closer to 15,000 ground peak rpm on a 90L engine. Something is wrong if its not breaking 14K rpm. Launching rich is ok... but it sounds like something is not quite right. I recommend putting the engine back on the test stand to check it and sort out if there is an issue. You should have recorded a baseline rpm from the run-in period. If you are seeing rpm down from that, time to find out what changed. (If you did not perform the run-in as per instructions, do that now before flying or attempting to run in in the airframe). Fuel being used is not the problem. The 15% heli fuel and extra oil is fine. Fuel spraying the carb and the engine running low on rpm indicates a possible exhaust restriction, or the engine is just a whole bunch on the rich side and struggling to get on the muffler. If you are using a diverter, remove that to for bench tests. Remider - Did you check the cylinder head bolts (retighten) after you performed the initial break in period ? Remove the muffler, look in the exhaust, and make sure the liner exhaust ports are centered (left to right) in the crankcase opening. PM me later on after you take a look. Bob
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
