Jett 1.00
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Jett 1.00
Page: [1]
Login
Jett 1.00 - 7/12/2007 2:14:30 AM
ArthurD
Status: offline
I bought a 1.00 Jett with in-cowl muffler several weeks ago, set it up on my test stand and broke it in. I then installed the intended prop, a 12X9 APC, and it would only turn 11,400 RPM with Morgan 15% fuel. Is this considered normal RPM? If not, what should I do next?
_____________________________
Arthur
       Post #: 1
RE: Jett 1.00 - 7/12/2007 9:46:55 PM
bob27s
Status: offline
quote:
ORIGINAL: ArthurD
Hi Arthur,
The turbo-jett muffler is going to run at lower rpm, but it will provide some additional torque.
11,400 on a 12x9 is pretty good. With some time on it, you can expect closer 12,000 on the ground. You may want to get in the first few flights with a bit lighter prop, say a 12x8 just to keep the engine happy the first few flights.
Get a few runs/flights on the engine, then fly with the 12x9, and subsequently try a heavier 12" prop ---- something along the lines of 12x10 or maybe even 12x11. You will get the speed out of the plane that way.
The turbo-jett you received with the engine is going to work best around 11,000-12,000 - so loading it down is ok, and letting it turn up a bit higher is ok too (also the reason the engine easily settles in around that 11,400 mark you noted)
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to ArthurD)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
