Building a QHOR, PQHOR, and a SPA3D    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Building a QHOR, PQHOR, and a SPA3D Page: <<   < prev  8 9 10 11 12 13 14 15 [16] 17   next >   >>
Login
Building a QHOR, PQHOR, and a SPA3D - 6/19/2003 11:09 AM
flyboone
Score: 100
Last Login: 9/23/2011
Status: offline
I use regular control horns. I also have twin airleron servos. You're gonna love this plane Tex. Just watch it though or your other planes will get jealous.
Jason
_____________________________
Jason Cole
Hide Signatures
(in reply to ben flyn)
       Post #: 376
Building a QHOR, PQHOR, and a SPA3D - 6/19/2003 7:35 PM
Steven Sloan
Score: 100
Last Login: 8/8/2004
Status: offline
Tattoo, Dave McD and myself outlined the definenition of a QHOR crash:
There has to be at lease three pieces come off the plane.
One or more pieces must be outside of a ten foot circle.
If it does not meet these requirements it was just a hard landing!
Steve
Hide Signatures
       Post #: 377
Building a QHOR, PQHOR, and a SPA3D - 6/19/2003 7:45 PM
BUCKETOBOLTS
Score: 100
Last Login: 5/21/2013
Status: offline
I believe I'm gonna scrounge up another servo and use two aileron servos on my next one. I'm also going to mount the servos for the rudder and elevator on the outside of the rail similar to Tattoo's. Anyone experimented with flaperon/spoileron mixing?
Since I already have a piece of 1/4 ply I'm going to make my motor mount out of it. The last one I used 3/8" UHMW poly and it did well till it started to sag. Alittle down thrust helped harrieres but when it drooped to almost 45 degrees I figured it was time to retire that one. It would do one heck of an outside loop.
Hide Signatures
       Post #: 378
Building a QHOR, PQHOR, and a SPA3D - 6/19/2003 8:20 PM
Goinstraightup
Score: 100
Last Login: 5/22/2013
Status: offline
I also use regular control horns....
Just happened to have a Pizazz that "didn't need them anymore".
Hide Signatures
       Post #: 379
Building a QHOR, PQHOR, and a SPA3D - 6/20/2003 1:10 AM
hoveralot
Score: 100
Last Login: 11/3/2009
Status: offline
I have a question for you guys, my Spa3d does not have a good roll rate, it is not bad for normal flight but for wild snaps and other stuff are too slow. Servo is mounted like the one Tatoo has in the web page with 35 or 40 degrees for each side but my Super Wasp and another fun fly (called Sexy) is a lot faster than this one. Is this normal in this design? are the ailerons flexing?
Any suggestions??
I thing this airplane has very good elevator control so flaperons are not needed, in fact in my first flight with it, I did a Loop really funny I just slow down the plane until it almost falls and then applied full power with full elevator and the airplane almost pivot in its center, also harriers are so easy that you can fly in a harrier attitude and then pull back throttle a little bit and go to an elevator before landing.
This weekend will try to get some more stick time so I can get used to fly backward while in hover.
Hide Signatures
       Post #: 380
Building a QHOR, PQHOR, and a SPA3D - 6/20/2003 3:41 AM
JoeLang
Score: 100
Last Login: 10/28/2012
Status: offline
[QUOTE]Originally posted by hoveralot
Any suggestions??
[/QUOTE]
Hoveralot, Did you install the the 5/32" x 18" music wire in the flute in front of the ailerons as per the drawings? I think your slow roll rate is due to flexing. I had the same problem until I added the music wire. I had built my SPA3D before the plans were finalized and just went by the description given in one of the threads. I was getting some flutter too before I added the wires.
Joe L.
Hide Signatures
       Post #: 381
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 1:07 AM
hoveralot
Score: 100
Status: offline
Hi Joe,
Yes I did install the Music Wire, but probably is that I am too used to have really fast roll rates, Yesterday I installed a larger servo arm so It can create more degrees in the ailerons (45º) but can´t test fly it until weekend (today is Friday ).
Next Sunday I will post again because the first flights where too short so this weekend should give me enough time to get some clues about this matter.
Hide Signatures
       Post #: 382
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 1:19 AM
mtthomps
Score: 100
Last Login: 12/16/2003
Status: offline
FYI - I ordered some pushrod material from Central Hobbies. The .156 OD carbon fiber tubes are very reasonably priced, and they will snug fit into the flutes very well and tight (So you can re-use them in another plane - don't glue them in). They are also VERY lightweight, and VERY stiff. This is what I will use in my SPA3d.
Hide Signatures
       Post #: 383
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 1:20 AM
jchuston
Score: 100
Last Login: 4/4/2006
Status: offline
anyone us a 40 LA on these things...I looked through the posts and may have missed it...if it was there...
I have a 40 LA from my Avistar Select...I love that plane but I want to put the engine to use on something else...tight now I am flying the Ultra Stick with a 46 FX on it...I like it but am afraid to get crazy because I don't wanna put it in...with the cheap 40 LA and a $10 plane...no reason to not get wild!!
Let me know if you think that a 40 LA will handle the 40 sized QHOR well...
Also, what do you use to decorate...will monokote stick...I am afraid to put heat on it...also, how about Sharpie permanent markers...I have lots of colors of those...Also, I bought whits corroplast...so any color will show up...should...
Thanks guys!!
-John
AMA 739303
Hide Signatures
       Post #: 384
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 1:23 AM
jchuston
Score: 100
Status: offline
oh yeah, if I don't want to buy an 8' section of PVC downspout, what should I use for control horns or as spacers when screwing down the corroplast to the alum. channel??
-John
AMA 739303
Hide Signatures
       Post #: 385
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 1:25 AM
JohnVH
Score: 160
Last Login: 5/19/2013
Status: offline
I tried a FP40 and a LA46, on the smaller one, and both were margional on hover power, it may hover, but wont pull out. Id buy a BB motor, alot more power and fun! I put a OS.40sf on it, now its a rocket! I have not tried a .40 on the larger bird yet, I might pull the .75 off to try it.
[quote]ORIGINAL: jefflangton
Time to bend over and let your head pop out!!!![/quote]
Hide Signatures
       Post #: 386
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 3:17 AM
jchuston
Score: 100
Status: offline
So, if I am putting a 40 LA on the plane (only option, I cannot buy another engine) then I should build the smaller of the QHORs...not the 40 sized??
-John
AMA 739303
Hide Signatures
       Post #: 387
Tattoo
Score: 100
Last Login: 4/14/2008
Status: offline
Although I havent done it since I have gutterpipe scraps out the yazoo...I have seen at LOWES in the gutterpipe isle that there is all kinds of smaller PVC gutterpipe joiners, connectors, brackets...stuff like that...I'm sure something like that would work fine for horns and back plates. I've also heard of a guy using a plastic electrical box to make them from. In fact, I would be interested in anything besides the gutterpipe that anyone finds that would work...heck...some good thick tupperware might even work
Hide Signatures
       Post #: 388
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 3:58 AM
BUCKETOBOLTS
Score: 100
Status: offline
On my first plane which was 32in wing I ran an OS 40fp with a Mouse Can Pipe. It ran really great. Turns a 11x4 acp at 12000, close to the FX performance. I am going to use the FX 46 on my new Spa3d, no replacement for displacement.
Hide Signatures
       Post #: 389
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 4:05 AM
Hacker
Score: 100
Last Login: 3/13/2008
Status: offline
[QUOTE]Originally posted by BUCKETOBOLTS
, . I am going to use the FX 46 on my new Spa3d, no replacement for displacement. [/QUOTE]
Bucket...be ready for some majior flutter issues....But i do like your saying..."no replacment for displacment"
Hide Signatures
       Post #: 390
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 7:33 AM
Dave McDonald
Score: 115
Status: offline
jchuston,
Your 40LA will work fine on a 30" or 32" Qhor or Pqhor with an 11x4 prop. But to get the pulling power from a vertical hover, you're going to want a mouse can pipe.
McDDD
ProBro 415
Hide Signatures
       Post #: 391
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 7:46 AM
JohnVH
Score: 160
Status: offline
[QUOTE]Originally posted by jchuston
-John
[/QUOTE]
I would build a smaller one, I have not run the MCPipe on any of my engines yet, but aparently that will wake them up a bit, even on the small one your not going to have good vertical without the MCP.
But it will fly fine.
Hide Signatures
       Post #: 392
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 8:50 AM
BUCKETOBOLTS
Score: 100
Status: offline
I had a flutter one time on my last one. The cleavis came off of the rudder, really did some major fluttering the top to the rudder was slapping each side of the elevator. Other than that she don't flutter much in a harrier or when going verticle.
Hide Signatures
       Post #: 393
Control Horns - 6/21/2003 9:43 AM
toywizard
Score: 100
Last Login: 3/27/2013
Status: offline
I use these..........
When you get the window shades that you can close by turning a control wand and they have little plastic mounts for the bottom of the window frame, most of us don't use them in the windows.
I don't use them because then you have to unhook the shade in order to raise it up.
So...........I save these mounts which are perfect for control horns. Just drill the holes you need. The size is already perfect and most people throw them away.
I also have used aluminum angle and sliced as needed.
Course if you want somthing that can't be killed, you can use an "L" bracket from the hardware store. I have never paid for anything as exotic as that but........... ;-)
If you know anyone with old aluminum roofing that either just installed or is removing it, a one foot piece of that will give you a lifetime of metal to make quick control horns out of.
Still thinking...........hmmmmmmm..
Never Give Up
www.twwrc.homestead.com/current.html
Hide Signatures
       Post #: 394
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 10:10 AM
Tattoo
Score: 100
Status: offline
What type of clevises do you use when you use aluminum horns? This sounds interesting! Does the clevis pin or horn wear from vibration? Have you had any problems with radio interfearence?...man how simple it would be to just make horns from the same stick of U channel as the fuselage ...cool idea!
Man...window shade brackets..holy cow, I wonder what one could find by walking up and down the dinky small dorky stuff isle at LOWES...should be all kinds of small angled stuff
Hide Signatures
       Post #: 395
Control Horns - 6/21/2003 11:16 AM
toywizard
Score: 100
Status: offline
Hi Tattoo
I havn't had any radio interfearence noticed and as far as wear, most of my planes don't last long enough to "wear" out. lol
I use "Z" bends and the plastic "clip" together type of clevises such as that come with the old foamy lazy bee and the Hobbico sky runner. Cheesy but work great.
I have the good ones but I tend to "save" stuff for "someday".
Just like my wife saves "paper" for someday. lol
I have still yet to build a qHOR. i HAVE ALL the stuff just in the process of tearing down my 12'x12' work shop so I can dig down 5 ft and build a .............ready? a 12'x60' !!!!!!!!!!!11
I will have some room to build planes yet!
Funny, I have more coroplast and blucore to build with then I have room to build.
I will solve that little problem this summer.
Just finished gutting out the old shop. and have a temp shop 8'x12' to cram everything into.
Never Give Up
Hide Signatures
       Post #: 396
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 9:41 PM
JoeLang
Score: 100
Status: offline
Thanks guys!!
-John
[/QUOTE]
JC, Go to a Dollar Store and pick up a couple of rolls of different colored self-adhesive vinyl used for lining shelves or whatever. Just peel and apply. Only - ONE DOLLAR!!!
Joe L.
Hide Signatures
       Post #: 397
Building a QHOR, PQHOR, and a SPA3D - 6/21/2003 11:20 PM
Texas 3D
Score: 100
Last Login: 6/19/2007
Status: offline
[QUOTE]Originally posted by JoeLang
JC, Go to a Dollar Store and pick up a couple of rolls of different colored self-adhesive vinyl used for lining shelves or whatever. Just peel and apply. Only - ONE DOLLAR!!! [/QUOTE]
I use monkote trim sheets.
Ulf
Hide Signatures
       Post #: 398
Building a QHOR, PQHOR, and a SPA3D - 6/22/2003 6:23 AM
lomcevek1
Score: 110
Last Login: 1/27/2012
Status: offline
Almost finished with my SPA3D but I think I will have almost as much invested as in my balsa profiles
The sign shop where I got the Corroplast had all the people very interested in the airplane and showed me this new color changing vinyl and they could cut out a set of flames to go on the wing. Now these colors change from purple to blue to green depending on which way you look at it. It would look SOOOO COOL so I - - - - - - - - - - DID i got them done at $20 a side. That was alomost done for cost because I said I would put their logo on the body but they are going to be AWESOME floating in a hover right in front of you !!
Hide Signatures
       Post #: 399
Building a QHOR, PQHOR, and a SPA3D - 6/22/2003 9:48 AM
jchuston
Score: 100
Status: offline
Hey all...
I have a problem...I cannot get any more coro for a while and when I was scoring the three flutes for the fold in the wing (on the .40 QHOR) I accidentally cut all the way through in some places...(probably a total of about 3-4 inches out of the entire 36" wingspan...
Is this piece ruined (as far as being used for a wing) or could I put some good 'ol Duct tape over the crack (whick will form a Duct tape leading edge) and hope that this works??
Let me know what you think from your experience with these things...
-John
AMA 739303
Hide Signatures
       Post #: 400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.641RCU1
