Building a QHOR, PQHOR, and a SPA3D    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Building a QHOR, PQHOR, and a SPA3D
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 12:19 AM
Woodman-RCU
Score: 100
Last Login: 11/16/2011
Status: offline
Great design Tatoo! Built it saturday, flew it sunday, grinning ear to ear! OS .32 with a 34" span.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ben flyn)
       Post #: 76
Knife Edge? Tatoo - 4/1/2003 12:22 AM
Kevins_RC
Score: 100
Last Login: 3/20/2013
Status: offline
Tatoo - will your new QHOR (aka - Awesome - HOR ) knife edge? I was hoping that with the profile style fuse that it might be a possibility, pending on its rigidity.
And, how did you fasten the profile fuse to the top of the wing? I believe that you said that you cut the fuse out after you positioned the wing to the aluminum fuse (back bone).
I am thinking of doing a 'AWE-HOR' with individual aileron servos (probably Hitec 225's, so I can play with mixing), and counter balanced rudder and elevator. This is way I am asking these questions. Also, where are you finding the PVC gutter pipe. I've checked my local sources (ACE hardware, Lowes, Home Depot) without any luck.
Thanks!
Kevin
_____________________________
Kevin
http://www.hsrcm.com
Hide Signatures
       Post #: 77
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 12:29 AM
Woodman-RCU
Score: 100
Status: offline
One more..
Click for fullsize
Hide Signatures
       Post #: 78
Re: Knife Edge? Tatoo - 4/1/2003 1:53 AM
Hacker
Score: 100
Last Login: 3/13/2008
Status: offline
[QUOTE]Originally posted by kevin4hsrcm
Thanks!
Kevin
[/QUOTE]
hey there Kevin,
tell me how long of a piece you need....i will mail you some.
just cut out all the parts last nite...will assembel mine tonite then post some pics.....wierd shopping at home depot and wal mart for r.c. parts
Hide Signatures
       Post #: 79
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 2:27 AM
Kevins_RC
Score: 100
Status: offline
Hacker - I think that I am one thread behind you!
I need gutter pipe to make about 10 PBFs, and 10 QHORs. I think my club has finally got the bug - PBF bug! I would like to see it turn into a SPAD BUG! . Don't worry Hacker, I'll find it someplace! Thanks anyways! Meantime, I've been using the conventional control horns. They work just fine. I just have a couple of more bucks, literally, in my PBF (Though reuseable on the next SPAD )
Woodman - I like it! I really like the way you mounted your fuel tank too - conventional profile method. This gets the fuel pick-up more in line with the carb! Nice job! I think I am going to starting drawing up my tail feathers & fuse tonight on CAD.
Kevin
Kevin
Hide Signatures
       Post #: 80
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 3:30 AM
Woodman-RCU
Score: 100
Status: offline
Hey thanks Kevin. Yeah I have been through the flooded engine stage with my past combat planes. The engine mount er.... cutting board poly stuff sticks out just far enough to catch the tank. I used a very small cup hook screwed into the poly motor mount and secured it with rubberbands.
I think on my next HOR I will split the elevator and use a y-yoke pushrod with individual horns on each half of the elevator. Then I will extend the rudder down past the elevator with a skeg on the bottom. Maybe this will help with the knife edge performance. I had a lot of coupling with my plane. It knife edged like my old retired wasp....
Woodman
Hide Signatures
       Post #: 81
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 5:35 AM
Kevins_RC
Score: 100
Status: offline
Woodman - I was thinking of mounting the elevator servo on its side on the underside of the aluminum rail so that I can set-up a Pull-Pull on both the rudder and elevator. I do plan on incorporating a wire skid in the tail to semi-protect the elevator servo on the bottom. I am debating on staggering the tail surfaces. I probably start-off semi-stk set-up (over-sized surfaces, of course ). I printed out the TACO II's profile fuse from Paul's plans. I will probably use it for the profile fuse to start-off with.
As far as the coupling in the knifed edge, that doesn't bother me, as long as it knifed edges, that's fine!
Kevin
Kevin
Hide Signatures
       Post #: 82
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 6:35 AM
Tattoo
Score: 100
Last Login: 4/14/2008
Status: offline
Mine tries to knife edge, but I don't think it's the aircraft's fault it rolls out...I'd blame the pilot's brain for failure to be able to turn left while flying sideways and feed ailerons at the same time...Yahoooo! But I'm starting to get the hang of it and I think the plane can do it...man I'm having a blast with this!
Oh yeah, and as an addition to the existing QHOR plans, I did up a few pages for the Profile QHOR (PQHOR) if anyone is interested
http://members.cox.net/spad/pics/pqhor01.jpg
http://members.cox.net/spad/pics/pqhor02.jpg
http://members.cox.net/spad/pics/pqhor03.jpg
http://members.cox.net/spad/pics/pqhor04.jpg
Hide Signatures
       Post #: 83
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 6:38 AM
Woodman-RCU
Score: 100
Status: offline
That'll work!Drop a little weight as well. The possibilities are endless with this design. Cheap to!
Hide Signatures
       Post #: 84
Tattoo - 4/1/2003 6:50 AM
flynfool
Score: 100
Last Login: 1/17/2010
Status: offline
Could you post some dimensions on the ailerons and tail dimensions, I really like your plane.
Hide Signatures
       Post #: 85
I FOUND IT - 4/1/2003 6:56 AM
flynfool
Score: 100
Status: offline
Sorry Tattoo I just wasn't looking I guess,, I found the dimensions.
Hide Signatures
       Post #: 86
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 6:59 AM
Woodman-RCU
Score: 100
Status: offline
Tattoo, That seems to be a lot of my problem too!! Ha!
Hide Signatures
       Post #: 87
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 7:01 AM
Woodman-RCU
Score: 100
Status: offline
I don't know flynfool, you should have the demensions memorized after yesterday....Hahahahaha!!!
Hide Signatures
       Post #: 88
Woodster - 4/1/2003 7:12 AM
flynfool
Score: 100
Status: offline
Yours doesn't look like Tattoo's.lol Don't tell Ronnie,,LOL.
Hide Signatures
       Post #: 89
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 7:20 AM
Woodman-RCU
Score: 100
Status: offline
No, I'll just suprise him sunday when I bring out the "Sukhor" complete with enlarged control surfaces! He will be two steps behind then....LOL!
Hide Signatures
       Post #: 90
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 9:35 AM
kamlooper
Score: 100
Last Login: 1/23/2012
Status: offline
Sukhor.....??!! Damn you beat me to it. I'll have to make mine a TopCap-hor. But I'm still one up on ya's for having the first video out....lol.
Hide Signatures
       Post #: 91
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 10:01 AM
ben flyn
Score: 110
Last Login: 9/7/2005
Status: offline
kamlooper
Video? What video?
Hide Signatures
       Post #: 92
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 11:32 AM
kamlooper
Score: 100
Status: offline
[URL=http://www.rcuniverse.com/forum/tm.asp?m=643263]This thread[/URL]]
Hide Signatures
       Post #: 93
COVERING THE QHOR??? - 4/1/2003 12:03 PM
art43
Score: 100
Last Login: 5/24/2008
Status: offline
Can you guys give me some hints on what to use use for covering this thing?And how. Thanks art43
art43 Professor of Bovine Scatology
Hide Signatures
       Post #: 94
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 1:03 PM
kamlooper
Score: 100
Status: offline
Art43, coroplast doesnt need covering! We just use scraps of vynil from sign shops for decoration and trim.
Hide Signatures
       Post #: 95
COVERING - 4/1/2003 1:45 PM
art43
Score: 100
Status: offline
So the vynil is fuel proof? What do u do with the Coro. wipe it down with Alcohol first, befor using your vynil? Thanks art43
Hide Signatures
       Post #: 96
Building a QHOR, PQHOR, and a SPA3D - 4/1/2003 4:31 PM
ben flyn
Score: 110
Status: offline
[So the vynil is fuel proof? What do u do with the Coro. wipe it down with Alcohol first, befor using your vynil?
QHOR's are just great flying signs or great flying sign material. If you use vinyl from sign shops, it and the coro, are designed together to take heat, sun, chemicals even fuel! Just make sure it's clean from oils so, yes, wipe it down with alcohol.
BTW, You can get some neat reflective colors that are like road signs!
Hide Signatures
       Post #: 97
Building a QHOR, PQHOR, and a SPA3D - 4/2/2003 3:14 AM
Ratchet
Score: 100
Last Login: 11/18/2012
Status: offline
Thanks Tattoo ...
You're the best !! Those 4 pages you did up answer all my questions.
-R
Hide Signatures
       Post #: 98
Building a QHOR, PQHOR, and a SPA3D - 4/3/2003 11:04 AM
Tattoo
Score: 100
Status: offline
quote:
any instructions or link on how to build that GeeBeeGhor ?
Here's the dimensions
http://members.cox.net/spad/pics/geebeepqhor.jpg
Hide Signatures
       Post #: 99
Building a QHOR, PQHOR, and a SPA3D - 4/3/2003 9:34 PM
m.gramling
Score: 101
Last Login: 8/30/2012
Status: offline
I got to wring out my Qhor yesturday. I really like this plane with a 40FP and moosecan. I was flying it in 20mph gusting up to 30mph. At times the wind you blow me backwards. but we were flying harriers backwards. I never thought I would fly in wind like yesturday. Now I know that I can fly the Qhor in just about any wind.
Everybody wants to go to heaven, but nobody wants to die...
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
